주요 콘텐츠로 건너뛰기
How to Repair a Stuffed Teddy Bear
필요한 것
  1. How to Repair a Stuffed Teddy Bear, How to Repair a Stuffed Teddy Bear: 1 단계, 이미지 1개 중 1개
    • Gather all necessary materials as listed on the bottom of the page. Be sure you have a clean, clear place to work with lots of light.
  2. How to Repair a Stuffed Teddy Bear: 2 단계, 이미지 1개 중 1개
    • Using a pair of scissors, make an incision approximately 3 inches in length along the middle major seam on the back of the stuffed animal (a seam ripper may also be used to open an existing seam).
  3. How to Repair a Stuffed Teddy Bear: 3 단계, 이미지 1개 중 1개
    • Remove all of the stuffing through the created incision and set it nearby to use later.
  4. How to Repair a Stuffed Teddy Bear: 4 단계, 이미지 1개 중 1개
    • Using cold water and mild soap, hand wash the fabric of the bear.
  5. How to Repair a Stuffed Teddy Bear: 5 단계, 이미지 1개 중 1개
    • Let the fabric air dry on a clothes hanger. (If you are in a hurry, use a hair dryer on the lowest setting or place in the dryer on a low temperature setting).
    • Hair dryer must be on lowest setting
    • Be careful to make sure the bear does not shrink in the dryer and check often
  6. How to Repair a Stuffed Teddy Bear: 6 단계, 이미지 1개 중 1개
    • Once the fabric is completely dry, refill the stuffed animal with new stuffing. Spread the stuffing evenly throughout the head, torso, and extremities.
    • The more stuffing added, the more dense the stuffed animal will become.
  7. How to Repair a Stuffed Teddy Bear: 7 단계, 이미지 1개 중 1개
    • Now that the stuffed animal is re-stuffed, the incision needs to be sewn closed. Thread a needle with thread matching the fabric of the stuffed animal by pushing the thread through the small hole (eye) of the needle.
    • Choose the length of your thread based on the length of the incision. Approx. 2-3 feet of thread will work well for a 3 inch incision.
    • You may need a magnifying glass as the eye of the needle is really small and may be difficult to see.
  8. How to Repair a Stuffed Teddy Bear: 8 단계, 이미지 1개 중 1개
    • Once your needle is threaded, you will want to secure the thread by tying a basic loop knot at the bottom of the thread to prevent the thread from slipping out as you sew the bear back together.
  9. How to Repair a Stuffed Teddy Bear: 9 단계, 이미지 1개 중 1개
    • Starting at one end of the incision, insert the needle through a small section of the fabric, pull until the tail end of the thread is about 2 inches from being pulled through the fabric. Grab the tail of the thread and tie it to the base of the thread you pulled through the fabric. Tuck the short excess tail thread into the stuffed animal.
    • Create small stitches joining the two sides along the length of the incision. Keep stitches tight and close together.
  10. How to Repair a Stuffed Teddy Bear: 10 단계, 이미지 1개 중 1개
    • Once you reach the other end of the incision, tie off your thread by creating another small knot.
  11. How to Repair a Stuffed Teddy Bear: 11 단계, 이미지 1개 중 1개
    • The excess thread can be hidden by running your needle inside the fabric and back out an inch away, cutting the thread close to the surface of the fabric, and then tugging on the fabric to make the end of the thread disappear inside the stuffed animal.
    • This sewing technique can also be used to repair fallen or ripped limbs.
  12. How to Repair a Stuffed Teddy Bear, Replacing a Missing Eye with a Button: 12 단계, 이미지 1개 중 1개
    • Replacing a Missing Eye
    • Gather all necessary supplies
  13. How to Repair a Stuffed Teddy Bear: 13 단계, 이미지 1개 중 1개
    • Set up a needle; discussed in Step 3 in the Threading a Needle Section.
  14. How to Repair a Stuffed Teddy Bear: 14 단계, 이미지 1개 중 1개
    • Before you begin, place the button in the location where you would like it to be attached. Attach your thread to the stuffed animal in this location, and thread the button onto the needle.
    • A Disclaimer: This guide uses the stuffed bear as an example scenario and provides instruction on the proper way to attach a button, but the button will not be attached to the bear in this demonstration.
  15. How to Repair a Stuffed Teddy Bear: 15 단계, 이미지 1개 중 1개
    • Run the needle through the hole above.
  16. How to Repair a Stuffed Teddy Bear: 16 단계, 이미지 1개 중 1개
    • Bring the needle back through the button, through the hole located diagonally to the previous hole.
  17. How to Repair a Stuffed Teddy Bear: 17 단계, 이미지 1개 중 1개
    • Bring the needle back to the front of the button.
    • Repeat steps 15-17 until the button is secure.
  18. How to Repair a Stuffed Teddy Bear: 18 단계, 이미지 1개 중 1개
    • Pass the needle through to the back of the button.
    • Make a knot and tie it.
    • Cut any excess thread.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
William Fernandez
회원 가입일: 09/11/15
203 평판
안내서 1개를 작성함
Sam Houston State, Team 15-4, Nardone Fall 2015 Sam Houston State, Team 15-4, Nardone Fall 2015 회원
SHSU-NARDONE-F15S15G4
4 회원들
안내서 2개를 작성함
3가이드 댓글
What do you do for a stuffed toy thats fabric has worn thin in spots? How do you reinforce the fabric to stay together and not leak filling?
ariel.condray - 답글
I thought about an iron on patch on the interior but I'm worried the sticky and heat will melt the original
ariel.condray -
What if the bear has brown plastic eyes? Not buttons... 🤔 or even glass eyes?
Old Teddy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 25
지난 30일: 84
전체 시간: 23,146
