주요 콘텐츠로 건너뛰기
How to Replace Scott Mountain Bike Handlebars
Sean Slater
Sean Slater4 다른 기여자
최종 수정일 March 3, 2017
30 - 45 분
조정
액션 샷
Need to replace the handlebars on your mountain bike? This guide will show you how to replace it so the bike is good as new.
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: 1 단계, 이미지 2개 중 1개 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: 1 단계, 이미지 2개 중 2개
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: 2 단계, 이미지 1개 중 1개
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: 3 단계, 이미지 1개 중 1개
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: 4 단계, 이미지 1개 중 1개
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: 5 단계, 이미지 1개 중 1개
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: 6 단계, 이미지 1개 중 1개
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: 7 단계, 이미지 1개 중 1개
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: 8 단계, 이미지 1개 중 1개
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
결론
By following these steps, you will have your bike ready in no time.
작성자
4다른 기여자 명과 함께
Sean Slater
회원 가입일: 02/24/15
139 평판
안내서 1개를 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 8
전체 시간: 1,849
