How to Restring Your Lacrosse Stick
The string job in your lacrosse head effects your playing much more than many people realize, and it can be extremely difficult to play well and consistently with a poorly strung stick. There are many different methods and techniques to string your own stick, all creating a different final result. Finding a stringing method that best suits you is all a matter of practice, but this guide will provide the basics to experiment with stringing to find the method and pattern that you prefer.
필요한 것
부품
도구
더보기...
Unstring current lacrosse netting on head and gather the necessary stringing supplies. You may cut the current strings, but I recommend keeping the mesh in tact for future stringing.
Cut your strings to the appropriate size. I generally cut the top string to be a little over a meter long, and both of the sidewall strings to be a little less than a meter.
Melt the ends of the string to prevent fraying. After melting, I lick my fingers and pinch the tips of the string to create a pointy tip that is easier to string. Have caution when pinching the tip, if your fingers are not salivated, you will burn yourself.
다른 6명이 해당 안내서를 완성하였습니다.
