주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Run First Aid with Disk Utility
    1. How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: 1 단계, 이미지 2개 중 1개 How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: 1 단계, 이미지 2개 중 2개
      • Open Disk Utilities, which can be found in the Applications folder under Utilities
      • Pro Tip: Take the shortcut and use Spotlight. (This method is used in this guide)
      댓글 쓰기
    2. How to Run First Aid with Disk Utility: 2 단계, 이미지 2개 중 1개 How to Run First Aid with Disk Utility: 2 단계, 이미지 2개 중 2개
      • Once the Disk Utility App opens, click the "View" menu.
      • Select "Show All Devices"
      • Older versions of macOS may not have this button. If so, skip to the next step.
      댓글 쓰기
    3. How to Run First Aid with Disk Utility: 3 단계, 이미지 1개 중 1개
      • In the Sidebar, click the last volume in the list.
      • By default it will likely be named "Macintosh HD - Data" or simply "Macintosh HD" on Macs running 10.14 Mojave or earlier.
      댓글 쓰기
    4. How to Run First Aid with Disk Utility: 4 단계, 이미지 3개 중 1개 How to Run First Aid with Disk Utility: 4 단계, 이미지 3개 중 2개 How to Run First Aid with Disk Utility: 4 단계, 이미지 3개 중 3개
      • Click on the First Aid button at the top of the window.
      • A dialogue box will appear asking if you would like to run First Aid.
      • Click "Run".
      • A second dialogue box will pop up prompting for acknowledgement that verifying your startup disk will cause it to be non-responsive.
      • Click “Continue”.
      댓글 쓰기
    5. How to Run First Aid with Disk Utility: 5 단계, 이미지 3개 중 1개 How to Run First Aid with Disk Utility: 5 단계, 이미지 3개 중 2개 How to Run First Aid with Disk Utility: 5 단계, 이미지 3개 중 3개
      • This procedure will take a few minutes to complete. The machine may freeze up, or lock up during this procedure.
      • Patience is key here.
      • Disk repair may fail, or give an error message. Restart your machine and run it again if this is the case, it may repair further issues.
      • Once completed, click done.
      • Pro Tip: To see the entire process including corrected errors, click on the arrow next to 'Show Details'.
      • Repeat this on all items in the Disk Utility list for your internal drive. Move upward through the list. Order of operations is all volumes first, then the container and finally the disk itself.
      댓글 쓰기
    6. How to Run First Aid with Disk Utility: 6 단계, 이미지 1개 중 1개
      • If you continue to receive errors, repeat this process using the Disk Utility function in Internet Recovery.
      댓글 쓰기
결론
Close Disk Utility, and the internal drive should be ready to go.
취소: 해당 안내서를 완성하지 않았습니다.
다른 44명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mike
회원 가입일: 11/01/10
14,505 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 51
지난 30일: 283
전체 시간: 23,130
