주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Splice Wire
필요한 것
  1. How to Splice Wire, Prepare your work area: 1 단계, 이미지 2개 중 1개 How to Splice Wire, Prepare your work area: 1 단계, 이미지 2개 중 2개
    • Set your tools down on a clean, non-flammable surface.
    • Ensure that the work area is well-ventilated and clear of anything that can be damaged during soldering.
    • Attach a stripped wire end to each of the helping hands clips, facing the ends towards each other.
    댓글 쓰기
  2. How to Splice Wire: 2 단계, 이미지 1개 중 1개
    • Cut a piece of heat-shrink tubing such that it's 10-15 mm longer than one of the exposed wire ends.
    • Slip the heat shrink over one of the wires, making sure to move the heat shrink away from the soldering point as to avoid any burning.
    댓글 쓰기
  3. How to Splice Wire, Intermesh the wire strands: 3 단계, 이미지 3개 중 1개 How to Splice Wire, Intermesh the wire strands: 3 단계, 이미지 3개 중 2개 How to Splice Wire, Intermesh the wire strands: 3 단계, 이미지 3개 중 3개
    • This step shows how to physically intermesh stranded wires together. This improves the physical properties of the joined wires.
    • Unravel all of the wire strands for both the wires, intermesh them, and then twist the strands together.
    댓글 쓰기
  4. How to Splice Wire, Heat up the wires: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixHub Smart Soldering Iron
    $79.95
    • Place the tip of a soldering iron against the exposed wires. You want to heat the wires hot enough such that they'll readily melt the solder.
    • Position the tip such that you maximize the wire surface area it touches.
    댓글 쓰기
  5. How to Splice Wire, Apply solder wire: 5 단계, 이미지 2개 중 1개 How to Splice Wire, Apply solder wire: 5 단계, 이미지 2개 중 2개
    • Slowly feed solder wire into the heated wire. The wire strands should readily absorb the molten solder.
    • If the solder pools on top of the wire strands, the strands aren't hot enough to melt the solder. Try moving the soldering iron so that the tip touches more of the strands.
    • Feed solder wire along the exposed wire until everything is thinly coated.
    • Once the molten solder saturates the wire strands, allow the solder joint to cool down and solidify (2-3 minutes).
    댓글 쓰기
  6. How to Splice Wire, Cover the exposed solder joint: 6 단계, 이미지 3개 중 1개 How to Splice Wire, Cover the exposed solder joint: 6 단계, 이미지 3개 중 2개 How to Splice Wire, Cover the exposed solder joint: 6 단계, 이미지 3개 중 3개
    • Slide the heat-shrink over the exposed solder joint so that it completely covers the joint and the surrounding insulation.
    • The heat-shrink acts as insulation for the wire.
    • Wave a heat source (lighter or heat gun) over the heat-shrink material to activate it. Apply heat until the heat-shrink has shrunk securely around the solder joint.
    댓글 쓰기
결론
You have successfully soldered two wires together!
For more soldering tips and guides, click here.
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Justin N/A Nguyen
회원 가입일: 02/20/24
376 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 45
지난 7일: 393
지난 30일: 1,474
전체 시간: 29,758
