주요 콘텐츠로 건너뛰기
How to Tighten a Loose Bicycle Handle
Sukhdit Saini
Sukhdit Saini다른 한 명의 기여자
최종 수정일 August 14, 2024
2 분
매우 쉬움
It is very common for a bicycle's handlebar to loosen up over time. Continuously riding the bicycle over a rough terrain may cause a screw on the handle to loosen up from all the consistent vibrations. It is very dangerous to ride a bicycle with a loose handle. Specifically, you may encounter a loss of control over the bicycle, which can make it difficult to steer and maintain balance over the road, leading to a serious injury. Additionally, there is a high chance of a sudden failure in the handlebar. This failure may cause the handle to unexpectedly detach from the bicycle itself, causing a serious accident. To avoid these injuries it is necessary to tighten your handle bar so that you do not get into any accidents that may harm you or others around you. If your Huffy Granite 24" bicycle has a loose handlebar, then this guide will provide you with simple step-by-step instructions to tighten the handle.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. How to Tighten a Loose Bicycle Handle, How to Tighten a Loose Bicycle Handle: 1 단계, 이미지 1개 중 1개
    • Stand up the bicycle.
    • It is difficult to work with a bicycle that is laying down for this fix.
  2. How to Tighten a Loose Bicycle Handle: 2 단계, 이미지 2개 중 1개 How to Tighten a Loose Bicycle Handle: 2 단계, 이미지 2개 중 2개
    • Align the handle bar with the front tire.
  3. How to Tighten a Loose Bicycle Handle: 3 단계, 이미지 3개 중 1개 How to Tighten a Loose Bicycle Handle: 3 단계, 이미지 3개 중 2개 How to Tighten a Loose Bicycle Handle: 3 단계, 이미지 3개 중 3개
    • Insert the 5.5mm Allen wrench inside the Allen screw on the top of the handlebar.
    • Rotate the wrench clockwise to tighten the screw.
  4. How to Tighten a Loose Bicycle Handle: 4 단계, 이미지 3개 중 1개 How to Tighten a Loose Bicycle Handle: 4 단계, 이미지 3개 중 2개 How to Tighten a Loose Bicycle Handle: 4 단계, 이미지 3개 중 3개
    • Confirm if the handle has been completely tightened.
    • If not, then redo Step 3 to tighten the screw even more.
결론
There is no need to take your bicycle to a repair shop to tighten the handles when you can complete the task at home in less than 5 minutes.
작성자
1다른 기여자 명과 함께
Sukhdit Saini
회원 가입일: 07/04/24
109 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 209
