주요 콘텐츠로 건너뛰기
How to Tighten the Nishiki Aero II Chain
Tobias Elder
Tobias Elder6 다른 기여자
최종 수정일 May 17, 2022
5 - 15 분
조정
Chain tension is important for the proper operation of your bike.
If the chain is too loose, then the derailleur may not function optimally, and the chain isn't as coupled with the bike's gears.
This guide shows you how to tighten your chain by simply nudging the rear wheel farther back in its housing, placing more tension on the chain so that it is no longer loose.
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: 1 단계, 이미지 1개 중 1개
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: 2 단계, 이미지 3개 중 1개 How to Tighten the Nishiki Aero II Chain: 2 단계, 이미지 3개 중 2개 How to Tighten the Nishiki Aero II Chain: 2 단계, 이미지 3개 중 3개
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: 3 단계, 이미지 1개 중 1개
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: 4 단계, 이미지 1개 중 1개
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
결론
작성자
6다른 기여자 명과 함께
Tobias Elder
회원 가입일: 04/25/13
113 평판
안내서 7개를 작성함
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G53
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 1,441
