주요 콘텐츠로 건너뛰기
How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Heat the bottom edge: 1 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: 2 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: 2 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 3 단계, 이미지 2개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 3 단계, 이미지 2개 중 2개
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Heat the right edge: 4 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
  5. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 5 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 5 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 5 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Heat the top edge: 6 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  7. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 7 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 7 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 7 단계, 이미지 3개 중 3개
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  8. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Heat the left edge: 8 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the left edge of the back cover for two minutes.
  9. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 9 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 9 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 9 단계, 이미지 3개 중 3개
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
  10. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the back cover: 10 단계, 이미지 2개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the back cover: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using double-sided tape, follow this guide.
  11. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 11 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 11 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: 11 단계, 이미지 3개 중 3개
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Be careful of the cable that runs beneath the charging coil. Work slowly and stop sliding the pick if it catches on the cable.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  12. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 12 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 12 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus: 12 단계, 이미지 3개 중 3개
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  13. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the charging coil: 13 단계, 이미지 2개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the charging coil: 13 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  14. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the NFC antenna: 14 단계, 이미지 2개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the NFC antenna: 14 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  15. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Unfasten the NFC antenna & charging coil assembly screws: 15 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  16. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: 16 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: 16 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  17. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the battery cable: 17 단계, 이미지 2개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the battery cable: 17 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  18. How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: 18 단계, 이미지 3개 중 1개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: 18 단계, 이미지 3개 중 2개 How to disconnect the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: 18 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
결론
Dominik Schnabelrauch
회원 가입일: 11/23/16
228,990 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,418개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 7
전체 시간: 12
