주요 콘텐츠로 건너뛰기
How to fix a ripped back pocket of jeans
Ashley Dembroski
Ashley Dembroski다른 한 명의 기여자
최종 수정일 July 16, 2021
15 - 30 분
조정
Use this guide to help you repair your ripped back pocket in your jeans.
In this guide you will need your ripped back pocket jeans. The reason this guide is needed is because back pockets are important to hold things such as your wallet, keys or cell phone.
There is no real special skills needed for this fix, my hope is that this guide will be enough that any person can sew their ripped jeans.
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: 1 단계, 이미지 3개 중 1개 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: 1 단계, 이미지 3개 중 2개 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: 1 단계, 이미지 3개 중 3개
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: 2 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 2 단계, 이미지 2개 중 2개
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: 3 단계, 이미지 1개 중 1개
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: 4 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 4 단계, 이미지 2개 중 2개
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: 5 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 5 단계, 이미지 2개 중 2개
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: 6 단계, 이미지 2개 중 1개 How to fix a ripped back pocket of jeans: 6 단계, 이미지 2개 중 2개
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: 7 단계, 이미지 3개 중 1개 How to fix a ripped back pocket of jeans: 7 단계, 이미지 3개 중 2개 How to fix a ripped back pocket of jeans: 7 단계, 이미지 3개 중 3개
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: 8 단계, 이미지 1개 중 1개
    • Cut the loose threads to clean up the sewing.
결론
작성자
1다른 기여자 명과 함께
Ashley Dembroski
회원 가입일: 07/19/20
157 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G2, Cardinal Summer 2020 UW Tacoma, Team S1-G2, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G2
1 회원
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 35
전체 시간: 4,088
