주요 콘텐츠로 건너뛰기
How to fix the Acer Chromebook 11 C733 Wi-Fi Issue
Jacob Mehnert
Jacob Mehnert2 다른 기여자
최종 수정일 May 7, 2024
10 분
쉬움
커뮤니티-기여 안내서
One of the more documented issues users have experienced with their Acer C733 Chromebook is the device dropping Wi-Fi and not regaining it. While there can be many reasons for a device to drop the Wi-Fi signal, there is a particular instance of this that is specific to the C733's design.
Specifically, this is caused by the placement of a rubber spacer near the M.2 slot on the device's logic board. If that spacer isn't in the correct place, then it can cause the logic board to flex whenever the computer is moved. This will result in the pins in the M.2 slot bending out of place and will result in the Wi-Fi card not having a proper connection.
While this guide will walk you through how to go about making this adjustment, there is also an official PDF provided by Acer that is featured on the iFixit Acer C733 page and in this guide.
필요한 것
도구
추천 문서
    • Make sure your device is powered off
    • Not doing so can result in damage to your device or can result in injury.
  1. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Open up your device: 2 단계, 이미지 2개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Open up your device: 2 단계, 이미지 2개 중 2개
    • Close your Chromebook and flip the device over so that the bottom of the case is facing up.
    • Remove all 12 case screws from the bottom of the case.
    • Don't worry about making sure these screws are returned to the same spot because they're all the same size.
  2. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: 3 단계, 이미지 3개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: 3 단계, 이미지 3개 중 2개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Disconnect the battery: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The battery is only held in place with a piece of ESD Tape. Using a set of tweezers, carefully peel away the tape from one end.
    • Once the tape is removed, carefully unplug the battery from the logic board.
  3. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Wi-Fi Card: 4 단계, 이미지 2개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Wi-Fi Card: 4 단계, 이미지 2개 중 2개
    • Remove the M.2 Screw, and unplug the Wi-Fi Card from the Logic Board.
  4. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Removing and replacing the Spacer: 5 단계, 이미지 1개 중 1개
    • Using a set of tweezers, carefully remove the rubber spacer from the logic board.
  5. How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Placing the Spacer: 6 단계, 이미지 2개 중 1개 How to fix the Acer Chromebook 11 C733 Wi-Fi Issue, Placing the Spacer: 6 단계, 이미지 2개 중 2개
    • Once the spacer is removed, place the new spacer in the same area as shown.
결론
To reassemble your device, reconnect the battery and snap the bottom panel back on, and reinsert the case screws.
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
2다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
38,153 평판
안내서 50개를 작성함
iFanatics iFanatics 회원
Community
60 회원들
안내서 190개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 28
전체 시간: 1,290
