주요 콘텐츠로 건너뛰기
Huawei Honor 10 Loudspeaker Unit Removal
필요한 것
  1. Huawei Honor 10 Loudspeaker Unit Removal, Rear Glass: 1 단계, 이미지 1개 중 1개
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Loudspeaker Unit Removal: 2 단계, 이미지 3개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 2 단계, 이미지 3개 중 2개 Huawei Honor 10 Loudspeaker Unit Removal: 2 단계, 이미지 3개 중 3개
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Loudspeaker Unit Removal: 3 단계, 이미지 2개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 3 단계, 이미지 2개 중 2개
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Loudspeaker Unit Removal: 4 단계, 이미지 3개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 4 단계, 이미지 3개 중 2개 Huawei Honor 10 Loudspeaker Unit Removal: 4 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Loudspeaker Unit Removal: 5 단계, 이미지 2개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 5 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Loudspeaker Unit Removal: 6 단계, 이미지 2개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 6 단계, 이미지 2개 중 2개
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
  7. Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: 7 단계, 이미지 3개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: 7 단계, 이미지 3개 중 2개 Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: 7 단계, 이미지 3개 중 3개
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
  8. Huawei Honor 10 Loudspeaker Unit Removal: 8 단계, 이미지 1개 중 1개
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
  9. Huawei Honor 10 Loudspeaker Unit Removal: 9 단계, 이미지 2개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
  10. Huawei Honor 10 Loudspeaker Unit Removal: 10 단계, 이미지 2개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 10 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery flex cable.
  11. Huawei Honor 10 Loudspeaker Unit Removal, Loudspeaker Unit: 11 단계, 이미지 1개 중 1개
    • Remove the seven Phillips screws securing the loudspeaker unit:
    • Three silver 2.9 mm long screws
    • Four black 3.4 mm long screws
  12. Huawei Honor 10 Loudspeaker Unit Removal: 12 단계, 이미지 3개 중 1개 Huawei Honor 10 Loudspeaker Unit Removal: 12 단계, 이미지 3개 중 2개 Huawei Honor 10 Loudspeaker Unit Removal: 12 단계, 이미지 3개 중 3개
    • There's a little bit of adhesive under the loudspeaker. It's possible to remove the loudspeaker without heating the adhesive but if you're having a hard time removing it, you can use an iOpener to soften the adhesive.
    • Slide the flat end of a spudger under the right side of the loudspeaker unit.
    • Pry up the loudspeaker unit until you can get a good grip.
    • Remove the loudspeaker unit.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
230,367 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,545개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 27
지난 30일: 100
전체 시간: 3,951
