소개
Use this guide to replace the back cover of your Huawei Mate 10 Pro.
If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
필요한 것
Insert a SIM opening tool in the hole on the left side and push it in.
Remove the SIM card tray.
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 2개
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Thanks for good work you do
