주요 콘텐츠로 건너뛰기
Huawei Mate 10 Pro Charging Port Replacement
필요한 것
  1. Huawei Mate 10 Pro Charging Port Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  2. Huawei Mate 10 Pro Charging Port Replacement: 2 단계, 이미지 3개 중 1개 Huawei Mate 10 Pro Charging Port Replacement: 2 단계, 이미지 3개 중 2개 Huawei Mate 10 Pro Charging Port Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  3. Huawei Mate 10 Pro Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  4. Huawei Mate 10 Pro Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  5. Huawei Mate 10 Pro Charging Port Replacement, Shields: 5 단계, 이미지 3개 중 1개 Huawei Mate 10 Pro Charging Port Replacement, Shields: 5 단계, 이미지 3개 중 2개 Huawei Mate 10 Pro Charging Port Replacement, Shields: 5 단계, 이미지 3개 중 3개
    • Remove the twelve Phillips #00 screws.
    • Carefully remove the shields on top of the motherboard and the charging board.
    • In case the shields do not pop out easily on their own after you removed the Phillips screws, you can use the pointed end of a spudger to pry them out.
  6. Huawei Mate 10 Pro Charging Port Replacement, Charging Port: 6 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Charging Port Replacement, Charging Port: 6 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
  7. Huawei Mate 10 Pro Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Huawei Mate 10 Pro Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to carefully remove the charging port including its flex cable.
    • The charging port sits tightly in its recess. In case you have trouble removing it, use the flat end of a halberd spudger to pry it out.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
229,601 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,467개를 작성함
댓글 2개
Great tutorial! It has been a month without being able to charge my phone, and now it charges 2x as fast with my repair.
Bruce Panagopoulos - 답글
I recommend testing the USB C flex cable assembly before you reassemble the phone. As soon as it’s connected to the upper connector and the battery is plugged in the phone should be charging. Mine was broken from the factory but I went to a great local repair shop and got a new one, the guy said 1 out of 15 is broken from the factory. Great tutorial, successful repair.
Martin Olsson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 42
지난 30일: 110
전체 시간: 17,085
