Huawei Mate 8 Loudspeaker Replacement
Use this guide to replace the loudspeaker in your Huawei Mate 8.
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Remove the two Phillips #00 screws.
Use the flat end a spudger to disconnect the loudspeaker flex connector.
Use the pointy end of a spudger to pry out the daughterboard.
Remove the daughterboard.
Use the tip of a spudger on the left side of the loudspeaker to pry it out.
Remove the loudspeaker.
다른 4명이 해당 안내서를 완성하였습니다.
