주요 콘텐츠로 건너뛰기
Huawei Mate 9 Display Replacement
필요한 것
  1. Huawei Mate 9 Display Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei Mate 9 Display Replacement, Back Cover: 1 단계, 이미지 2/2
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Display Replacement: 2 단계, 이미지 1/2 Huawei Mate 9 Display Replacement: 2 단계, 이미지 2/2
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Display Replacement: 3 단계, 이미지 1/2 Huawei Mate 9 Display Replacement: 3 단계, 이미지 2/2
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
  4. Huawei Mate 9 Display Replacement, Battery Disconnect: 4 단계, 이미지 1/1
    • Carefully peel off the plastic sticker that holds both cables to the battery.
  5. Huawei Mate 9 Display Replacement: 5 단계, 이미지 1/1
    • Remove the water indicator sticker and the Phillips #00 screw beneath it, that holds the cable bracket in its place.
  6. Huawei Mate 9 Display Replacement: 6 단계, 이미지 1/1
    • Remove the cable bracket.
  7. Huawei Mate 9 Display Replacement: 7 단계, 이미지 1/3 Huawei Mate 9 Display Replacement: 7 단계, 이미지 2/3 Huawei Mate 9 Display Replacement: 7 단계, 이미지 3/3
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  8. Huawei Mate 9 Display Replacement, Display: 8 단계, 이미지 1/3 Huawei Mate 9 Display Replacement, Display: 8 단계, 이미지 2/3 Huawei Mate 9 Display Replacement, Display: 8 단계, 이미지 3/3
    • It's not required to remove the battery in order to remove the display of the Huawei Mate 9.
    • Disconnect the antenna cable and remove it carefully.
    • Remove the five Phillips #00 screws that hold the daughter board and loudspeaker in its place.
  9. Huawei Mate 9 Display Replacement: 9 단계, 이미지 1/2 Huawei Mate 9 Display Replacement: 9 단계, 이미지 2/2
    • Remove the metal shield that covers the connection of the motherboard flex cable.
    • Use a spudger to unplug the motherboard flex cable and remove it.
  10. Huawei Mate 9 Display Replacement: 10 단계, 이미지 1/2 Huawei Mate 9 Display Replacement: 10 단계, 이미지 2/2
    • Use a spudger to disconnect the loudspeaker and the charging port flex cable from the daughterboard.
  11. Huawei Mate 9 Display Replacement: 11 단계, 이미지 1/3 Huawei Mate 9 Display Replacement: 11 단계, 이미지 2/3 Huawei Mate 9 Display Replacement: 11 단계, 이미지 3/3
    • Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier.
    • Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky.
    • If you're having a hard time while removing the loudspeaker you can use an iOpener to loosen the adhesive and try it again.
  12. Huawei Mate 9 Display Replacement: 12 단계, 이미지 1/3 Huawei Mate 9 Display Replacement: 12 단계, 이미지 2/3 Huawei Mate 9 Display Replacement: 12 단계, 이미지 3/3
    • Use an iOpener to loosen the adhesive beneath the display. Focus on the top and bottom area of it.
    • After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display.
    • Do not insert the tool more than approximately 1/16 of an inch on the sides.
    • Loosen the adhesive by sliding the along the mid frame.
  13. Huawei Mate 9 Display Replacement: 13 단계, 이미지 1/3 Huawei Mate 9 Display Replacement: 13 단계, 이미지 2/3 Huawei Mate 9 Display Replacement: 13 단계, 이미지 3/3
    • Then carefully slide around the whole mid frame.
    • If you're having a hard time while loosening the adhesive beneath the display you can reuse the iOpener and try it again.
    • After you loosened all the adhesive, start to slowly lift up the display from the bottom of your phone.
  14. Huawei Mate 9 Display Replacement: 14 단계, 이미지 1/2 Huawei Mate 9 Display Replacement: 14 단계, 이미지 2/2
    • To completely remove the display you need to thread the flex cable through the gap in the mid frame.
    • When reassembling your phone apply new adhesive where it is necessary.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it is necessary.
다른 13명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,262 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,243개 작성하였습니다
댓글 7개
I have issue with the assembly process. Im adding 3m adhesive tape that I received with replacement screen, and everything looks fine. But after inserting phone into aluminium back the screen pop out int the middle of frame, delaminating and showing backlight of lcd. The adhesive just not hold it enough..
gingerboi66 - 답글
The iFlex isn’t listed in the tools.
Sean Hannold - 답글
Check, now it is listed. Thanks for the note.
Tobias Isakeit -
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
madani_salar - 답글
Hello,
do i have to remove the battery to change the display? That means is the removing of the battery absolutely necessary?
Greetings,
Mark
Mark D. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 31
30일 전: 106
전체 시간: 19,369
