주요 콘텐츠로 건너뛰기
Huawei P10 Lite Battery Disconnection
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Huawei P10 Lite Battery Disconnection, Back cover: 1 단계, 이미지 1/3 Huawei P10 Lite Battery Disconnection, Back cover: 1 단계, 이미지 2/3 Huawei P10 Lite Battery Disconnection, Back cover: 1 단계, 이미지 3/3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Battery Disconnection: 2 단계, 이미지 1/3 Huawei P10 Lite Battery Disconnection: 2 단계, 이미지 2/3 Huawei P10 Lite Battery Disconnection: 2 단계, 이미지 3/3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Battery Disconnection: 3 단계, 이미지 1/2 Huawei P10 Lite Battery Disconnection: 3 단계, 이미지 2/2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Battery Disconnection: 4 단계, 이미지 1/2 Huawei P10 Lite Battery Disconnection: 4 단계, 이미지 2/2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Battery Disconnection, Battery Disconnection: 5 단계, 이미지 1/3 Huawei P10 Lite Battery Disconnection, Battery Disconnection: 5 단계, 이미지 2/3 Huawei P10 Lite Battery Disconnection, Battery Disconnection: 5 단계, 이미지 3/3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
결론
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,329 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 158
