소개
Use this guide to replace the rear camera in your Huawei P10 Lite smartphone. When reassembling your phone apply new adhesive where it is necessary.
필요한 것
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
Remove the Phillips screw holding the battery connector plate in place.
Remove the battery connector plate.
Use the flat end of a spudger to disconnect the battery flex cable.
Use the flat end of a spudger to disconnect the rear camera flex cable.
Remove the rear camera.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
다른 한 분이 해당 안내서를 완성하였습니다.
