주요 콘텐츠로 건너뛰기
Huawei S10 Tablet  USB Charge Port Replacement
Harvey
Harvey2 다른 기여자
최종 수정일 August 5, 2024
10 - 15 분
쉬움
커뮤니티-기여 안내서
  1. Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: 1 단계, 이미지 2개 중 1개 Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: 1 단계, 이미지 2개 중 2개
    • Open the cover and press the SIM card and Micro SD card in to release them both.
    • Remove the screw under the hinge cover.
  2. Huawei S10 Tablet  USB Charge Port Replacement, Remove Back Cover: 2 단계, 이미지 1개 중 1개
    • Use a prying tool to loosen the back cover from the display.
    • There are plastic clips holding the display and back cover together, but they come apart quite easily.
  3. Huawei S10 Tablet  USB Charge Port Replacement, Remover Display Cable: 3 단계, 이미지 1개 중 1개
    • Carefully separate the display unit from the back cover, but not too far.
    • There is a cable connecting the two together.
    • Lift the ZIF Connector and remove the Display Cable.
    • Lay the display to one side.
  4. Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: 4 단계, 이미지 2개 중 1개 Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: 4 단계, 이미지 2개 중 2개
    • Flip the ZIF connector to loosen the flex cable for the USB charger port.
    • It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
    • Remove the two screws holding the charger port in place.
  5. Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: 5 단계, 이미지 2개 중 1개 Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: 5 단계, 이미지 2개 중 2개
    • Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
    • Insert the display into the back cover.
    • Replace the screw by the SIM card / Micro SD card slot.
    • Completed!
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Harvey
회원 가입일: 02/15/16
5,820 평판
안내서 10개를 작성함
댓글 3개
Is this charger available
Doyin Nwakanma - 답글
Charger port for Huawei s10
Doyin Nwakanma - 답글
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
Doyin Nwakanma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 30
전체 시간: 3,039
