Humax RM-H01U Remote Disassembly
The remote has a bottom and top part. They are held together with plastic clips.
Don't forget to remove the battery, just for good measure.
Use a spudger, prying tool or a flatbed screwdriver to pry open the two halves. Start at the center.
The two halves are clamped together firmly.
Work your way to the front, and then back again on the other side.
See the next step for the location of the clips.
The clips are located 3 centimeters apart. The first clip is 1 centimeter from the front of the remote.
The hooks of the clips are on the bottom halve of the remote and face inward.
The top halve of the remote has indents where the clips grab into.
These are all the parts.
I cleaned all parts with a toothbrush first.
Then I cleaned the PCB and the back of the silicone buttons with pure alcohol.
다른 한 분이 해당 안내서를 완성하였습니다.
