주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HyperX Cloud Alpha Headband Replacement
필요한 것
    1. HyperX Cloud Alpha Headband Replacement, Headband: 1 단계, 이미지 1개 중 1개
      • Remove the two Phillips #1 screws from the clips located on the headband.
      • Repeat on the other clip. (If you did the right side first, then do the left and vice-versa.)
      댓글 쓰기
    2. HyperX Cloud Alpha Headband Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the black plastic clips, freeing the metal sliding band inside.
      댓글 쓰기
    3. HyperX Cloud Alpha Headband Replacement: 3 단계, 이미지 3개 중 1개 HyperX Cloud Alpha Headband Replacement: 3 단계, 이미지 3개 중 2개 HyperX Cloud Alpha Headband Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the worn band.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Shelsea Rodriguez
회원 가입일: 10/25/22
195 평판
안내서 1개를 작성함
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G4
5 회원들
안내서 18개를 작성함
3가이드 댓글
¿Y qué hago con el cable que cruza dentro de la almohadilla? No puedo reemplazarlo si este está cruzado entre los dos extremos del auricular y dentro de la almohadilla misma.
Daniel Cetina Bastida - 답글 공유
This guide feels like it's missing several steps. I tried taking apart the HyperX Cloud 1 which is put together pretty much the same way. As you show in Step 2 there's a cable that runs through the headband that connects the left cup to the right cup. If your goal is to replace a worn headband, you would basically have to disconnect the cable from one of the cups which is a soldered connection, draw it out through the headband, thread it back through your replacement headband, and re-solder the cable to the cup, no? That seems like an important omission.
In my case I have no soldering skills so I opted to just cut the old headband open to get the cable free, then I put it back together with just the metal sliding band and no headband.
Terry - 답글 공유
This is just full wrong and missleading. You need to solder things to replace headband
Stanislav Shostak - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 117
지난 30일: 436
전체 시간: 13,493
