주요 콘텐츠로 건너뛰기
IBM ThinkPad T41 CMOS Battery Replacement
Marissa Blustein
Marissa Blustein9 다른 기여자
최종 수정일 July 25, 2024
15 - 20 분
조정
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its BIOS battery.
Do not uninstall the battery when is Setting a Supervisor Password!
필요한 것
부품
도구
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
더보기...
  1. IBM ThinkPad T41 CMOS Battery Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    You need to remove the battery, hard drive, and UltraDrive before starting step 1.
    cak - 답글
  2. IBM ThinkPad T41 CMOS Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    If there's extra RAM under the cover, remove it by spreading the retaining clips.
    cak - 답글
  3. IBM ThinkPad T41 CMOS Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 CMOS Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 CMOS Battery Replacement, Trackpad: 5 단계, 이미지 1개 중 1개
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. IBM ThinkPad T41 CMOS Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the five screws that were hidden by the stickers.
  7. IBM ThinkPad T41 CMOS Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  8. IBM ThinkPad T41 CMOS Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  9. IBM ThinkPad T41 CMOS Battery Replacement, CMOS Battery: 9 단계, 이미지 1개 중 1개
    • Lift the yellow plastic-covered battery up.
  10. IBM ThinkPad T41 CMOS Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Unplug the battery connector.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Marissa Blustein
회원 가입일: 04/16/10
534 평판
안내서 12개를 작성함
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 회원
CPSU-MANESS-S10S7G8
4 회원들
안내서 29개를 작성함
댓글 6개
You will need to buy the dc jack that has the the wire harness on it, the wires in the computer are soldered to the jack so if you try to use them will result in a smaller wire to work with and you will not beable to connect the ribbon from the monitor to the MB
Shawn Fontaine - 답글
It is absolutely unnecessary to remove all of the screws as shown in the first image, in fact it would be counter productive to do so. One need only remove the screws that have a symbol of either the keyboard, the palm rest or both. The screw locations also have numeral indicators adjacent to them showing the specific size screw for that location.
For easy battery replacement follow these video guides:
http://support.lenovo.com/en_US/product-...
and
James Maugham - 답글
great review, for rtc / cmos batteries try http://bestbattery.biz/IBM/225980-ThinkP...
the battery life is excellent
Kermit45 - 답글
thank you very much for your help
For easy battery replacement follow these video guides : https://www.youtube.com/watch?v=8ZI-8Q2j...
reda salut - 답글
Is there a quicker way to get to the CMOS battery interface? What alternate step could be used when using a CMOS AAA battery replacement instead? If possible, send me an email in response to this comment. Thanks in advance.
Jim Farrell - 답글
Gibt es so eine Anleitung auch für das ibm think pad 600e type 2645 ich wollte die bios batterie wechseln. Hab den gesamten Laptop auseinander gebaut, hab aber keine cmos Batterie zum austauschen gefunden.🙁
Hymurwa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 114
전체 시간: 66,350
