IBM ThinkPad T42 Modem Daughter Board Replacement
This guide will demonstrate the removal and replacement procedures for an IBM ThinkPad T42 Modem Daughter Board.
필요한 것
Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
다른 2명이 해당 안내서를 완성하였습니다.
