주요 콘텐츠로 건너뛰기
IBM ThinkPad T42 Wi-Fi Card Replacement
Kevin Rehm
Kevin Rehm9 다른 기여자
최종 수정일 January 17, 2025
25 - 40 분
쉬움
더 나은 이미지가 필요함
누락된 단계
마크업 사고
더 나은 소개글
An IBM ThinkPad T42 Wi-Fi card allows the device to connect to a wireless network. If your Wi-Fi card is broken or needs to be replaced, this guide will show you how.
필요한 것
도구
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: 2 단계, 이미지 1개 중 1개
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: 3 단계, 이미지 1개 중 1개
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 1개 중 1개
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully pull it out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Kevin Rehm
회원 가입일: 04/19/10
472 평판
안내서 4개를 작성함
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 37개를 작성함
댓글 2개
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - 답글
The only screws that need to be removed are the ones that are numbered 1-4 on the bottom of the case. Best to remove the screws with #4 next to them, then remove the keyboard and then remove 1-3 and then the palm rest. Removing the ones on the rear is unnecessary.
John Casey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 24
전체 시간: 13,902
