주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IdeaPad L340-15API Battery Replacement
필요한 것
    1. IdeaPad L340-15API Battery Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 IdeaPad L340-15API Battery Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
      댓글 쓰기
    2. IdeaPad L340-15API Battery Replacement: 2 단계, 이미지 2개 중 1개 IdeaPad L340-15API Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
      댓글 쓰기
    3. IdeaPad L340-15API Battery Replacement: 3 단계, 이미지 2개 중 1개 IdeaPad L340-15API Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
      댓글 쓰기
    1. IdeaPad L340-15API Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 IdeaPad L340-15API Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
      댓글 쓰기
    2. IdeaPad L340-15API Battery Replacement: 5 단계, 이미지 3개 중 1개 IdeaPad L340-15API Battery Replacement: 5 단계, 이미지 3개 중 2개 IdeaPad L340-15API Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Insert a plastic opening pick in the back left corner and wedge the panel open.
      • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
      • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
      • Remove the bottom cover.
      댓글 쓰기
    3. IdeaPad L340-15API Battery Replacement: 6 단계, 이미지 2개 중 1개 IdeaPad L340-15API Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
      • Use a container/magnet strip to store the screws while working.
      댓글 쓰기
    4. IdeaPad L340-15API Battery Replacement: 7 단계, 이미지 3개 중 1개 IdeaPad L340-15API Battery Replacement: 7 단계, 이미지 3개 중 2개 IdeaPad L340-15API Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      댓글 쓰기
    5. IdeaPad L340-15API Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the battery from the laptop.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Ian
회원 가입일: 10/15/25
347 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 회원
UMASSD-BOWMAN-F25S2G5
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 56
전체 시간: 390
