주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia NS-CLLT01 Button Replacement
필요한 것
    1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: 1 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: 1 단계, 이미지 2개 중 2개
      • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
      댓글 쓰기
    2. Insignia NS-CLLT01 Button Replacement: 2 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 Button Replacement: 2 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 Button Replacement: 2 단계, 이미지 3개 중 3개
      • On the bottom of the clock, use your fingernail to push the battery cover to the right.
      • Lift the battery cover up and to the right to reveal the batteries.
      댓글 쓰기
    3. Insignia NS-CLLT01 Button Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
      • Once the batteries are removed, close the cover.
      댓글 쓰기
    4. Insignia NS-CLLT01 Button Replacement: 4 단계, 이미지 1개 중 1개
      • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
      • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
      • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
      댓글 쓰기
    5. Insignia NS-CLLT01 Button Replacement: 5 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 Button Replacement: 5 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 Button Replacement: 5 단계, 이미지 3개 중 3개
      • Turn the clock back over.
      • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
      댓글 쓰기
    1. Insignia NS-CLLT01 Button Replacement, Button: 6 단계, 이미지 1개 중 1개
      • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
      댓글 쓰기
    2. Insignia NS-CLLT01 Button Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the circuit board from the device.
      댓글 쓰기
    3. Insignia NS-CLLT01 Button Replacement: 8 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 Button Replacement: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
      댓글 쓰기
    4. Insignia NS-CLLT01 Button Replacement: 9 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 Button Replacement: 9 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 Button Replacement: 9 단계, 이미지 3개 중 3개
      • Use this soldering guide to remove and replace any buttons that were not working.
      • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Preston Jackson
회원 가입일: 09/23/15
201 평판
안내서 2개를 작성함
Baylor, Team 6-9, Williams Fall 2015 Baylor, Team 6-9, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G9
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 33
전체 시간: 664
