주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia NS-CLLT01 LCD Screen Replacement
필요한 것
    1. Insignia NS-CLLT01 LCD Screen Replacement, Insignia NS-CLLT01 Top Casing Removal: 1 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement, Insignia NS-CLLT01 Top Casing Removal: 1 단계, 이미지 2개 중 2개
      • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
      댓글 쓰기
    2. Insignia NS-CLLT01 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
      • On the bottom of the clock, use your fingernail to push the battery cover to the right.
      • Lift the battery cover up and to the right to reveal the batteries.
      댓글 쓰기
    3. Insignia NS-CLLT01 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
      • Once the batteries are removed, close the cover.
      댓글 쓰기
    4. Insignia NS-CLLT01 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
      • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
      • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
      댓글 쓰기
    5. Insignia NS-CLLT01 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Turn the clock back over.
      • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
      댓글 쓰기
    1. Insignia NS-CLLT01 LCD Screen Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
      • Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
      댓글 쓰기
    2. Insignia NS-CLLT01 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the white ribbon connector that connects the central circuit board to the circuit board attached to the top of the clock by gripping it on both sides and pulling it straight away from the board.
      댓글 쓰기
    3. Insignia NS-CLLT01 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Unscrew the two 10mm screws from the bottom circuit board.
      댓글 쓰기
    4. Insignia NS-CLLT01 LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
      • Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
      • At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
      • The black radio antenna, which is attached to the board and comes out of the back of the clock, will need to be pushed into the clock from the outside as the board is lifted up.
      댓글 쓰기
    5. Insignia NS-CLLT01 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Once the ports on the back of the circuit board are displaced and resting against the back of the clock, use a pair of tweezers to lift the circuit board up off of the bottom of the clock, continuing to feed the radio antenna through the side of the clock as the board lifts up.
      댓글 쓰기
    6. Insignia NS-CLLT01 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Pull the radio antenna the rest of the way through the side of the clock.
      댓글 쓰기
    7. Insignia NS-CLLT01 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Turn the circuit board over.
      • Disconnect the two white connectors on the bottom of the circuit board by gripping the sides of each connector and pulling straight out.
      댓글 쓰기
    1. Insignia NS-CLLT01 LCD Screen Replacement, LCD Screen: 13 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement, LCD Screen: 13 단계, 이미지 2개 중 2개
      • Lift the adhesive strip that holds down the grey ribbon cable which attaches to the circuit board and the LCD screen.
      댓글 쓰기
    2. Insignia NS-CLLT01 LCD Screen Replacement: 14 단계, 이미지 3개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement: 14 단계, 이미지 3개 중 2개 Insignia NS-CLLT01 LCD Screen Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the screen by pushing it toward the middle of the clock and pulling it up out of the clock.
      댓글 쓰기
    3. Insignia NS-CLLT01 LCD Screen Replacement: 15 단계, 이미지 2개 중 1개 Insignia NS-CLLT01 LCD Screen Replacement: 15 단계, 이미지 2개 중 2개
      • Lift the adhesive strip that covers the connections between the grey ribbon cable and the circuit board by peeling it off of the circuit board.
      댓글 쓰기
    4. Insignia NS-CLLT01 LCD Screen Replacement: 16 단계, 이미지 1개 중 1개
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Shain Powell
회원 가입일: 09/22/15
101 평판
안내서 1개를 작성함
Baylor, Team 6-9, Williams Fall 2015 Baylor, Team 6-9, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G9
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 30
전체 시간: 986
