주요 콘텐츠로 건너뛰기
Insignia NS-F12R6-SS Oscillation Arm Replacement
필요한 것
  1. Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: 1 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: 1 단계, 이미지 2/2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Oscillation Arm Replacement: 2 단계, 이미지 1/1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Oscillation Arm Replacement: 3 단계, 이미지 1/1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Oscillation Arm Replacement, Fan Blade: 4 단계, 이미지 1/1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Oscillation Arm Replacement: 5 단계, 이미지 1/1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Oscillation Arm Replacement, Back Cage: 6 단계, 이미지 1/1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Oscillation Arm Replacement: 7 단계, 이미지 1/1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: 8 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: 8 단계, 이미지 2/2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Oscillation Arm Replacement: 9 단계, 이미지 1/1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Oscillation Arm Replacement, Motor Housing: 10 단계, 이미지 1/1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Oscillation Arm Replacement: 11 단계, 이미지 1/1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Oscillation Arm Replacement: 12 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 12 단계, 이미지 2/2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Oscillation Arm Replacement: 13 단계, 이미지 1/1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Oscillation Arm Replacement: 14 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 14 단계, 이미지 2/2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Oscillation Arm Replacement: 15 단계, 이미지 1/1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Oscillation Arm Replacement: 16 단계, 이미지 1/1
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: 17 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: 17 단계, 이미지 2/2
    • Using a Phillips #3 screwdriver, unscrew the the 16 mm long screw fastening the oscillation arm to the lower oscillation gear screw.
  18. Insignia NS-F12R6-SS Oscillation Arm Replacement: 18 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 18 단계, 이미지 2/2
    • Using a Phillips #3 screwdriver, unscrew and remove the 4 mm long bolt on the front face of the base that fastens the motor assembly to the base bolt.
  19. Insignia NS-F12R6-SS Oscillation Arm Replacement: 19 단계, 이미지 1/1
    • Remove the fan motor assembly from the base.
  20. Insignia NS-F12R6-SS Oscillation Arm Replacement: 20 단계, 이미지 1/2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 20 단계, 이미지 2/2
    • Using a Phillips #3 screwdriver, unscrew the 15 mm long bolt fastening the oscillation arm to the fan base bolt.
  21. Insignia NS-F12R6-SS Oscillation Arm Replacement: 21 단계, 이미지 1/1
    • Remove the oscillation arm.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hank
회원 가입일: 09/17/18
1,091 평판
안내서 8개 작성하였습니다
CSU Fullerton, Team S2-G1, Bruce Fall 2018 CSU Fullerton, Team S2-G1, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 378
