주요 콘텐츠로 건너뛰기
Inspiron 7359 2-in-1 Battery Replacement
Alfredo Acosta
Alfredo Acosta7 다른 기여자
최종 수정일 March 23, 2025
6 분
쉬움
학생이 작성 중
더 나은 소개글
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with a 3-cell, 43Wh battery, giving you 3-5 hours of battery life. Consider changing the battery if:
  1. You find that the battery life has decreased significantly (the computer only lasts an hour or two on a battery life alone).
  2. The battery starts to charge to full too slowly.
  3. Your device is alerting you of any critical battery failures.
Aside from the usual caution you'd give a battery, there's no real hazards involved with taking the backing of the computer off and replacing the battery. You won't need more than the actual replacement battery and a few tools to disassemble the computer, so follow this guide and keep your computer running for even longer. Just make sure to power off and disconnect the computer before you start taking it apart.
If you see that the battery has started swelling or leaking, please seek out professional technical assistance.
필요한 것
도구
더보기...
  1. Inspiron 7359 2-in-1 Battery Replacement, Bottom Case: 1 단계, 이미지 1개 중 1개
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Battery Replacement: 2 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Unscrew two 8mm screws with a Phillips #0 screwdriver.
    • Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Make sure to keep all screws together and label where you unscrewed them from.
  6. Inspiron 7359 2-in-1 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • To remove the old battery, lift from the bottom and pull the battery towards you.
결론
To reassemble your device, follow these instructions in reverse order using a new battery.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Alfredo Acosta
회원 가입일: 08/26/19
141 평판
안내서 1개를 작성함
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 38
지난 30일: 52
전체 시간: 185
