주요 콘텐츠로 건너뛰기
Inspiron 7359 2-in-1 WiFi Card Replacement
Annberlisa Ronald
Annberlisa Ronald6 다른 기여자
최종 수정일 March 23, 2025
10 분
쉬움
학생이 작성 중
더 나은 소개글
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with Wi-Fi 802.11ac 1×1 (Wi-Fi 5). Consider changing your WiFi card if:
  1. The computer is disconnecting from the WiFi frequently, even if you're close to the router.
  2. The WiFi is consistently slow, even when other devices on the same network are working fine.
  3. The computer isn't finding any WiFi networks or isn't connecting to any known networks.
  4. The WiFi strength is consistently weak or nonexistent, even when you're close to the router.
  5. You're getting error messages related to your WiFi router.
If you have determined that there's no other possible reason why your computer shouldn't be working, even after updates and connecting to other networks and making sure the router's not the problem, it might be a safe bet to replace the WiFi card. The WiFi card is not dangerous on its own, even if it's connected to a power source. Make sure to power off and disconnect the computer when you start taking your computer apart. You won't need more than the actual replacement WiFi card and a few tools to disassemble the computer, so follow this guide and keep your connection running smoothly.
필요한 것
도구
더보기...
  1. Inspiron 7359 2-in-1 WiFi Card Replacement, Bottom Case: 1 단계, 이미지 1개 중 1개
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 WiFi Card Replacement: 2 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 WiFi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 WiFi Card Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 WiFi Card Replacement: 4 단계, 이미지 1개 중 1개
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: 5 단계, 이미지 2개 중 1개 Inspiron 7359 2-in-1 WiFi Card Replacement, WiFi Card: 5 단계, 이미지 2개 중 2개
    • Use the spudger tool to remove the two antenna cables.
    • Remove the black screw.
    • Slightly pull up the end and remove the WiFi card. Be careful not to damage the internal adapter.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Annberlisa Ronald
회원 가입일: 08/26/19
109 평판
안내서 1개를 작성함
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 31
지난 30일: 40
전체 시간: 214
