주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Live 660NC Battery Replacement
필요한 것
    1. JBL Live 660NC Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 JBL Live 660NC Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 JBL Live 660NC Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • The battery is located in the left earcup. All steps in this guide must be performed on the left earcup.
      • Use a Jimmy or spudger to pry the bezel around the JBL plate.
      • Gently slide the tool around the edges to loosen the clips.
      • Lift the bezel off.
      댓글 쓰기
    2. JBL Live 660NC Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the three 5 mm screws with a Phillips #00 screwdriver.
      댓글 쓰기
    3. JBL Live 660NC Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Use a Tri-point Y0 screwdriver to remove the two 5 mm screws at the base of the headband where it connects to the earcup.
      댓글 쓰기
    4. JBL Live 660NC Battery Replacement: 4 단계, 이미지 3개 중 1개 JBL Live 660NC Battery Replacement: 4 단계, 이미지 3개 중 2개 JBL Live 660NC Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Use a nylon spudger or Jimmy to pry the earcup cover.
      • Gently slide the tool around the edges to loosen the clips holding the cover in place.
      • Lift the cover off.
      • Don't pull the cover off. The cover is still connected to the headphones by the battery cable.
      • Avoid using metal tools near the battery and other internal components Puncturing or shorting the battery can cause a fire or injury. Use a plastic or nylon opening tool instead.
      댓글 쓰기
    5. JBL Live 660NC Battery Replacement: 5 단계, 이미지 2개 중 1개 JBL Live 660NC Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Use a spudger to push the connector labeled BAT from the socket on the motherboard to disconnect the battery cable
      • Don’t pull on the wires—this can damage the connector and the device.
      댓글 쓰기
    6. JBL Live 660NC Battery Replacement: 6 단계, 이미지 2개 중 1개 JBL Live 660NC Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Use the tip of the spudger to push the plastic locking tab away from the socket labeled TH—it should only move about 1–2 mm.
      • Carefully remove the cable connector from the socket on the board.
      • Avoid pulling on the wires, and don’t twist or bend them.
      댓글 쓰기
    7. JBL Live 660NC Battery Replacement: 7 단계, 이미지 2개 중 1개 JBL Live 660NC Battery Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the battery from the inside cover.
      • If the battery looks swollen, don't attempt to remove it. Check out the What to Do With a Swollen Battery guide for additional information and instructions.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jailene Denova
회원 가입일: 10/01/25
229 평판
안내서 2개를 작성함
Austin Community College, Team 10-4, Watkins Fall 2025 Austin Community College, Team 10-4, Watkins Fall 2025 회원
AUSTINCC-WATKINS-F25S10G4
4 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 74
지난 30일: 201
전체 시간: 1,463
