주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Tune 510BT Power Button Replacement
필요한 것
  1. JBL Tune 510BT Power Button Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 JBL Tune 510BT Power Button Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
    댓글 쓰기
  2. JBL Tune 510BT Power Button Replacement: 2 단계, 이미지 2개 중 1개 JBL Tune 510BT Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
    댓글 쓰기
  3. JBL Tune 510BT Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
    댓글 쓰기
  4. JBL Tune 510BT Power Button Replacement, Power Button: 4 단계, 이미지 2개 중 1개 JBL Tune 510BT Power Button Replacement, Power Button: 4 단계, 이미지 2개 중 2개
    • Remove the 1 mm screw using a JIS #00 screwdriver.
    • Using your finger or a Jimmy, gently pry the circuit board from the casing, being careful to not pull too hard to dislodge the connected wires.
    댓글 쓰기
  5. JBL Tune 510BT Power Button Replacement: 5 단계, 이미지 2개 중 1개 JBL Tune 510BT Power Button Replacement: 5 단계, 이미지 2개 중 2개
    • Gently push the damaged power button from the outside towards the inner part of the headphone casing until it dislodges.
    • Replace it with the new button by connecting the tabs at the top and swinging the button into place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andy Rich
회원 가입일: 01/30/24
316 평판
안내서 2개를 작성함
Utah Tech University, Team 1-2, McMurrin Spring 2024 Utah Tech University, Team 1-2, McMurrin Spring 2024 회원
UTAHTECH-MCMURRIN-S24S1G2
2 회원들
안내서 11개를 작성함
2가이드 댓글
Ref. Power button ?
Marcel De Taey - 답글 공유
Part number to replace the powder button?? 510BT
Chris - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 74
지난 30일: 330
전체 시간: 7,184
