주요 콘텐츠로 건너뛰기
JD Razor 2000 Shocks Replacement
Kaylan Naicker
Kaylan Naicker2 다른 기여자
최종 수정일 August 3, 2023
5 - 30 분
쉬움
The shocks are located slightly above the front wheel of the JD Razor 2000 and assist the rider in braking and reduces stress on the load-bearing points of the scooter.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: 1 단계, 이미지 3개 중 1개 JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: 1 단계, 이미지 3개 중 2개 JD Razor 2000 Shocks Replacement, Removing the 1.75" Axle Bolt: 1 단계, 이미지 3개 중 3개
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Shocks Replacement, Removing the Wheel: 2 단계, 이미지 1개 중 1개
    • Grip the bottom of the wheel and gently slide it out.
  3. JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: 3 단계, 이미지 3개 중 1개 JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: 3 단계, 이미지 3개 중 2개 JD Razor 2000 Shocks Replacement, Removing the Shock's 1.75" Axle Bolt: 3 단계, 이미지 3개 중 3개
    • Find the axle bolt behind the shocks. It should look similar to the one used to remove the front wheel.
    • Remove the bolt in the same manner as the wheel. While applying pressure to the left side, unscrew the right using an Allen wrench.
    • If the left side of the bolt rotates when you attempt to unscrew the right, use a second Allen wrench to hold it in place.
    • If the bolt does not turn at all or does not turn easily, apply lubricant to the screw and try again in five minutes.
    • Remove the bolt and bearing and the black rubber stoppers. Remove the metal tube between the bolt.
  4. JD Razor 2000 Shocks Replacement, Removing the Wheel Holder and Shock: 4 단계, 이미지 2개 중 1개 JD Razor 2000 Shocks Replacement, Removing the Wheel Holder and Shock: 4 단계, 이미지 2개 중 2개
    • Firmly grasp the metal piece that holds the wheel and gently pull it away.
    • The shocks should fall out naturally by themselves. This is normal and expected. If they do not, gently pull the shocks out of their holders.
    • A metal cylinder is located inside the spring of the shock. Do not lose this.
결론
작성자
2다른 기여자 명과 함께
Kaylan Naicker
회원 가입일: 10/14/14
255 평판
안내서 2개를 작성함
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G46
4 회원들
안내서 16개를 작성함
댓글 한 개
I’ve been looking and can’t find the part that would fit here. Does anyone have any suggestions for compatible parts? The link at the top doesn’t work.
HotWheels - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 1,972
