주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jabra CRUISER2 Status Display Replacement
필요한 것
    1. Jabra CRUISER2 Status Display Replacement, Front Plate: 1 단계, 이미지 1개 중 1개
      • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
      • iOpener Instructions
      댓글 쓰기
    2. Jabra CRUISER2 Status Display Replacement: 2 단계, 이미지 1개 중 1개
      • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
      • Pull the tool toward the back of the device to pry it open.
      • Repeat this process over all edges of the device.
      댓글 쓰기
    3. Jabra CRUISER2 Status Display Replacement: 3 단계, 이미지 1개 중 1개
      • Open up the device by pulling the front plate straight up from the back plate.
      댓글 쓰기
    1. Jabra CRUISER2 Status Display Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Jabra CRUISER2 Status Display Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
      • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
      댓글 쓰기
    2. Jabra CRUISER2 Status Display Replacement: 5 단계, 이미지 1개 중 1개
      • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
      • The names of the screwdriver heads are listed on the sides of each head.
      댓글 쓰기
    3. Jabra CRUISER2 Status Display Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the motherboard from the device by lifting it up from the back plate.
      댓글 쓰기
    1. Jabra CRUISER2 Status Display Replacement, Status Display: 7 단계, 이미지 1개 중 1개
      • Using the PH000, unscrew the three 4.6mm screws in the status display.
      댓글 쓰기
    2. Jabra CRUISER2 Status Display Replacement: 8 단계, 이미지 2개 중 1개 Jabra CRUISER2 Status Display Replacement: 8 단계, 이미지 2개 중 2개
      • Disconnect the wires connecting the status display to the back plate. Do this by pulling the wire from the black socket.
      • Do this with the wires on both sides of the status board.
      댓글 쓰기
    3. Jabra CRUISER2 Status Display Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the status display by lifting it off of the back plate.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Spartacus
회원 가입일: 10/17/14
636 평판
안내서 5개를 작성함
Baylor, Team 8-13, Williams Fall 2014 Baylor, Team 8-13, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G13
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 672
