주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jam Voice Speaker Replacement
필요한 것
    1. Jam Voice Speaker Replacement, Hard Mesh Cover: 1 단계, 이미지 2개 중 1개 Jam Voice Speaker Replacement, Hard Mesh Cover: 1 단계, 이미지 2개 중 2개
      • Insert the plastic opening tool underneath the mesh top.
      • Pry the cover open.
      • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
      댓글 쓰기
    1. Jam Voice Speaker Replacement, Motherboard: 2 단계, 이미지 1개 중 1개
      • Remove the four 7mm Phillips screws from the plastic cover.
      댓글 쓰기
    2. Jam Voice Speaker Replacement: 3 단계, 이미지 2개 중 1개 Jam Voice Speaker Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the four 5mm Phillips screws that hold down the speaker in place.
      • Remove the two 6mm Phillips screws that hold down the plastic casing.
      댓글 쓰기
    3. Jam Voice Speaker Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Halberd Spudger
      $2.99
      • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
      • Pull the speaker up and out.
      댓글 쓰기
    4. Jam Voice Speaker Replacement: 5 단계, 이미지 3개 중 1개 Jam Voice Speaker Replacement: 5 단계, 이미지 3개 중 2개 Jam Voice Speaker Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the four 7mm Phillips screws to expose the motherboard.
      댓글 쓰기
    5. Jam Voice Speaker Replacement: 6 단계, 이미지 1개 중 1개
      • After removing all of the screws from the plastic cover, remove it by pulling up and out.
      • Be careful not to pull and damage any of the wires.
      댓글 쓰기
    6. Jam Voice Speaker Replacement: 7 단계, 이미지 2개 중 1개 Jam Voice Speaker Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the three 5mm Phillips screws that hold the motherboard in place.
      • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
      댓글 쓰기
    1. Jam Voice Speaker Replacement, Speaker: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to pull out the speaker's wire from the motherboard.
      • Use tweezers to pull out the battery's wire from the motherboard.
      • The speaker's connection point is opposite the battery's connection point.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Alexander Buck
회원 가입일: 04/05/18
358 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 32
전체 시간: 933
