주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jeans Button Replacement
필요한 것
  1. Jeans Button Replacement, Prepare: 1 단계, 이미지 3개 중 1개 Jeans Button Replacement, Prepare: 1 단계, 이미지 3개 중 2개 Jeans Button Replacement, Prepare: 1 단계, 이미지 3개 중 3개
    • Gather the replacement pieces, including a button and tack.
    • Lay the jeans front-side up on a sturdy table or workbench.
    • Unzip the fly and find the hole at the waistband where the previous button was located.
    • Remove all remnants of the old button before installing the new one. Discard the old pieces responsibly.
    댓글 쓰기
  2. Jeans Button Replacement, Insert the tack: 2 단계, 이미지 3개 중 1개 Jeans Button Replacement, Insert the tack: 2 단계, 이미지 3개 중 2개 Jeans Button Replacement, Insert the tack: 2 단계, 이미지 3개 중 3개
    • Insert the tack into the back of the hole.
    • Push the tack into the hole until it's flush with the waistband.
    • If the hole is more than 1/8 inch (~3mm) larger than the width of the tack, patch or reinforce the torn area before placing a new tack.
    댓글 쓰기
  3. Jeans Button Replacement, Place the button: 3 단계, 이미지 3개 중 1개 Jeans Button Replacement, Place the button: 3 단계, 이미지 3개 중 2개 Jeans Button Replacement, Place the button: 3 단계, 이미지 3개 중 3개
    • Holding the tack in place from behind, place the button on top of the tack and hold the pieces in place with your fingers.
    댓글 쓰기
  4. Jeans Button Replacement, Hammer the button: 4 단계, 이미지 3개 중 1개 Jeans Button Replacement, Hammer the button: 4 단계, 이미지 3개 중 2개 Jeans Button Replacement, Hammer the button: 4 단계, 이미지 3개 중 3개
    • Flip the jeans over and place a soft flat work surface directly beneath the button, like a soft piece of wood or leather.
    • A hard surface can damage the button.
    • Use a pair of needle nose pliers to hold the tack in place, making sure the tack and button pieces are still aligned.
    • Hammer the tack with a straight downward pound.
    • Use a small hammer or mallet (about one pound or 450 g) to avoid bending or breaking the button.
    • To further protect a button with a logo, place a soft cloth or towel underneath before hammering.
    댓글 쓰기
  5. Jeans Button Replacement, Quality control: 5 단계, 이미지 2개 중 1개 Jeans Button Replacement, Quality control: 5 단계, 이미지 2개 중 2개
    • Test the new button by buttoning the jeans and pulling on the waistband, to ensure it's set and secure.
    • The button shouldn't spin easily in place.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 51명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,933 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,617개를 작성함
10가이드 댓글
Nice, but let's consider how this situation occurs. The tack comes out of its hole, just simply replacing it is not realistic, unless the new tack is significantly bigger. So how do you "repair" the hole such that it will hold a tack again?
Gabe Misura - 답글 공유
As noted in step 2, you can move the tack over to where the denim isn't damaged. If that will cause the jeans not to fit properly, you can sew a folded piece of denim behind the hole (sew around the edges on the inside of the jeans) and punch the tack through the new piece.
Brittany McCrigler - 답글 공유
I didn´t have a new button and was in a pinch. Just ripped the old button off completely, jammed it in the tail end of a hammer and yanked it apart with som pliers. Then i followed the instructions in this fix. Worked like a charm, so far...
fredrikbendiksen - 답글 공유
Thanks I’m gonna try this first!
Lynsey Truhlicka - 답글 공유
The best thing to do is patch the hole. I simply use fabric glue and some pieces of blue jeans that you probably have hanging around. Trim off the extra threads and then apply fabric glue to the back of the waist band covering the hole made by the old button. Do the same on the front and then let dry. about 30 minutes or so, if you have a machine I always stitch back and for on the edges. Trim any edges or use additional glue to tack them down. Now because you have strengthened the hole carefully push the back of the button through where you can see the end, add the front to the nail end and turning the garment face down on a protected hard surface hammer about 3 times and check to see if it is sturdy, continue to hammer until you have reached the objective. Now you have got many more years with that button.
melanie1150 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 67
지난 7일: 420
지난 30일: 2,301
전체 시간: 553,407
