주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Joy-Con 2 (Left) Joystick Replacement
필요한 것
  1. Joy-Con 2 (Left) Joystick Replacement, Remove the right edge screws: 1 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the right edge screws: 1 단계, 이미지 2개 중 2개
    • Use a tri‑point Y00 driver to remove the two 3.1 mm‑long black screws on the right edge of the controller.
    댓글 쓰기
  2. Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap underneath the bumper button on the left side of the controller, with a point of the pick pointing downwards.
    • Pry up to slightly lift the plastic strip running across the left edge of the controller.
    댓글 쓰기
  3. Joy-Con 2 (Left) Joystick Replacement, Separate the plastic strip: 3 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Separate the plastic strip: 3 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Separate the plastic strip: 3 단계, 이미지 3개 중 3개
    • Slide the opening pick around to the front of the controller.
    • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
    댓글 쓰기
  4. Joy-Con 2 (Left) Joystick Replacement, Remove the plastic strip: 4 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the plastic strip: 4 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Remove the plastic strip: 4 단계, 이미지 3개 중 3개
    • Pry up on the bottom edge of the plastic strip with slow, steady force.
    • Repeat this prying action along the length of the strip until it's fully detached.
    댓글 쓰기
  5. Joy-Con 2 (Left) Joystick Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the plastic strip.
    댓글 쓰기
  6. Joy-Con 2 (Left) Joystick Replacement, Remove the left edge screws: 6 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the left edge screws: 6 단계, 이미지 2개 중 2개
    • Remove the two screws on the left edge of the controller:
    • One 3.1 mm‑long tri‑point Y00 black screw
    • One 3.0 mm‑long JIS 00 silver screw
    • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
    댓글 쓰기
  7. Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 3개
    • Don't try to remove the back cover yet.
    • Insert an opening pick into the gap between the front and back halves of the controller on its left side.
    • Slide the pick down the controller to disengage the clips.
    • Leave the opening pick at the bottom of the controller's left edge, just before its curve.
    • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
    댓글 쓰기
  8. Joy-Con 2 (Left) Joystick Replacement, Insert a second opening pick: 8 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Insert a second opening pick: 8 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Insert a second opening pick: 8 단계, 이미지 3개 중 3개
    • Hold the controller upside-down.
    • Insert a point of another opening pick next to the release button at the top of the controller.
    • Use the opening pick to press the release button through the gap.
    댓글 쓰기
  9. Joy-Con 2 (Left) Joystick Replacement, Release the back cover: 9 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Release the back cover: 9 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Release the back cover: 9 단계, 이미지 3개 중 3개
    • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
    • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
    • Open the back cover.
    댓글 쓰기
  10. Joy-Con 2 (Left) Joystick Replacement, Remove the back cover: 10 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the back cover: 10 단계, 이미지 2개 중 2개
    • Firmly grasp the two wires (blue and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
    • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
    • Remove the back cover.
    댓글 쓰기
  11. Joy-Con 2 (Left) Joystick Replacement, Disconnect the battery: 11 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the battery: 11 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the battery: 11 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to firmly grip the white JST connector and pull straight away from its socket to disconnect it.
    • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
    댓글 쓰기
  12. Joy-Con 2 (Left) Joystick Replacement, Remove the release button: 12 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the release button: 12 단계, 이미지 2개 중 2개
    • Pick up the release button and remove it.
    댓글 쓰기
  13. Joy-Con 2 (Left) Joystick Replacement, Remove the trigger: 13 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the trigger: 13 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Remove the trigger: 13 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap between the bumper (L) and trigger (ZL) buttons at the top of the controller.
    • Pry up on the ZL button to pop it off and remove it.
    • You can lightly hold the ZL button with your finger to avoid launching it.
    댓글 쓰기
  14. Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 14 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 14 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two screws securing the release button mounting bracket:
    • One 3.9 mm‑long silver screw
    • One 6.2 mm‑long black screw
    댓글 쓰기
  15. Joy-Con 2 (Left) Joystick Replacement, Remove the bracket: 15 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the bracket: 15 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Remove the bracket: 15 단계, 이미지 3개 중 3개
    • Insert an opening pick underneath the release button bracket.
    • Pry it away from the controller to remove it.
    댓글 쓰기
  16. Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 16 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the screws: 16 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the three 3.9 mm‑long silver screws securing the midframe.
    댓글 쓰기
  17. Joy-Con 2 (Left) Joystick Replacement, Remove the bumper: 17 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the bumper: 17 단계, 이미지 2개 중 2개
    • Hold the midframe lightly in place.
    • Pull the L bumper button off its mounting pegs and remove it.
    • The midframe will lift slightly when removing this button.
    댓글 쓰기
  18. Joy-Con 2 (Left) Joystick Replacement, Prop up the controller: 18 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Prop up the controller: 18 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Prop up the controller: 18 단계, 이미지 3개 중 3개
    • Use the back cover to prop up the controller while you work.
    • The buttons on the front of the controller should rest on the back cover's lip to keep it stable.
    댓글 쓰기
  19. Joy-Con 2 (Left) Joystick Replacement, Lift the trigger board: 19 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Lift the trigger board: 19 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the 3.9 mm‑long silver screw securing the trigger button board.
    댓글 쓰기
  20. Joy-Con 2 (Left) Joystick Replacement: 20 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 20 단계, 이미지 2개 중 2개
    • Insert the point of a spudger underneath the board, and lift it until it pops up.
    댓글 쓰기
  21. Joy-Con 2 (Left) Joystick Replacement, Remove the midframe: 21 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the midframe: 21 단계, 이미지 2개 중 2개
    • Pick up and remove the midframe.
    댓글 쓰기
  22. Joy-Con 2 (Left) Joystick Replacement, Disconnect the trigger board: 22 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the trigger board: 22 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the trigger board: 22 단계, 이미지 3개 중 3개
    • Use the point of a spudger to flip up the locking flap on the trigger button ZIF connector, located on the controller's board.
    댓글 쓰기
  23. Joy-Con 2 (Left) Joystick Replacement, Remove the trigger board: 23 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the trigger board: 23 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • Remove the trigger button board.
    댓글 쓰기
  24. Joy-Con 2 (Left) Joystick Replacement, Disconnect the joystick: 24 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Disconnect the joystick: 24 단계, 이미지 2개 중 2개
    • Use the point of a spudger to flip up the locking flap on the joystick cable ZIF connector, located in the center of the board.
    댓글 쓰기
  25. Joy-Con 2 (Left) Joystick Replacement: 25 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 25 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to grab the brown part of the cable and gently pull the cable out of its socket.
    댓글 쓰기
  26. Joy-Con 2 (Left) Joystick Replacement, Remove the board screws: 26 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the board screws: 26 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the five 3.1 mm‑long black screws securing the board to the controller.
    댓글 쓰기
  27. Joy-Con 2 (Left) Joystick Replacement, Lift the board: 27 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Lift the board: 27 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Lift the board: 27 단계, 이미지 3개 중 3개
    • Insert the point of a spudger underneath the board, next to the joystick, between the board and the frame.
    • Pry up slowly on the board to lift it until you can grab it with your fingers.
    • The black tape stuck to the joystick will stay with the board. Work slowly to avoid tearing the tape.
    댓글 쓰기
  28. Joy-Con 2 (Left) Joystick Replacement: 28 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 28 단계, 이미지 2개 중 2개
    • Use your fingers or a spudger to lift the joystick cable up so it's perpendicular to the joystick module.
    댓글 쓰기
  29. Joy-Con 2 (Left) Joystick Replacement: 29 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 29 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement: 29 단계, 이미지 3개 중 3개
    • Lift the board and flip it over the controller's inner edge.
    • Be careful not to crease or tear the two ribbon cables connecting the board to the controller.
    댓글 쓰기
  30. Joy-Con 2 (Left) Joystick Replacement, Remove the joystick: 30 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Remove the joystick: 30 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to remove the two 3.9 mm‑long silver screws securing the joystick.
    댓글 쓰기
  31. Joy-Con 2 (Left) Joystick Replacement: 31 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 31 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to pick up and remove the joystick.
    댓글 쓰기
  32. Joy-Con 2 (Left) Joystick Replacement, Disassembly complete: 32 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    댓글 쓰기
  33. Joy-Con 2 (Left) Joystick Replacement, Install the joystick: 33 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the joystick: 33 단계, 이미지 2개 중 2개
    • Align the circular cut-out in the joystick's frame with the peg near the controller's inner edge.
    • Set the joystick in the controller. Gently wiggle the joystick to ensure it's fully seated.
    댓글 쓰기
  34. Joy-Con 2 (Left) Joystick Replacement: 34 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 34 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the two 3.9 mm‑long silver screws securing the joystick.
    댓글 쓰기
  35. Joy-Con 2 (Left) Joystick Replacement, Install the board: 35 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the board: 35 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the board: 35 단계, 이미지 3개 중 3개
    • Lower the board into the controller at an angle so it sits underneath the locking tab on the controller's inner edge.
    • Use a spudger to bend the joystick's ribbon cable so it's perpendicular with the joystick.
    • Lower the board so the joystick's ribbon cable routes through the joystick cut-out in the board.
    댓글 쓰기
  36. Joy-Con 2 (Left) Joystick Replacement: 36 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 36 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement: 36 단계, 이미지 3개 중 3개
    • Push the board towards the controller's inner edge (the side with the shoulder buttons) to prevent it from colliding with the joystick module.
    • Lower the board into the frame.
    • Use your finger or the flat end of a spudger to press the black tape onto the back of the joystick module.
    댓글 쓰기
  37. Joy-Con 2 (Left) Joystick Replacement: 37 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 37 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the five 3.1 mm‑long black screws securing the board to the controller.
    댓글 쓰기
  38. Joy-Con 2 (Left) Joystick Replacement, Connect the joystick: 38 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the joystick: 38 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Connect the joystick: 38 단계, 이미지 3개 중 3개
    • Make sure the locking flap is flipped up on the joystick cable ZIF connector.
    • Insert the joystick ribbon cable into its ZIF connector until it's fully seated.
    • The brown portion of the cable should end at the golden line on the board.
    • Use your finger or a spudger to flip the locking flap down to secure the cable.
    댓글 쓰기
  39. Joy-Con 2 (Left) Joystick Replacement, Connect the trigger board: 39 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the trigger board: 39 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Connect the trigger board: 39 단계, 이미지 3개 중 3개
    • Make sure the locking flap is flipped up on the trigger cable's ZIF connector.
    • Position the trigger button board so its ribbon cable is aligned with its ZIF connector on the board.
    • Use tweezers or your fingers to gently slide the ribbon cable into its ZIF connector.
    • Flip the locking flap down to secure the cable.
    댓글 쓰기
  40. Joy-Con 2 (Left) Joystick Replacement, Install the midframe: 40 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the midframe: 40 단계, 이미지 2개 중 2개
    • Align the midframe with its screw holes on the outer edge of the controller and set it into place.
    댓글 쓰기
  41. Joy-Con 2 (Left) Joystick Replacement, Install the trigger button board: 41 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger button board: 41 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger button board: 41 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to set the bottom edge of the trigger button board underneath the tab on the midframe.
    • Press the board into place so the black peg on the midframe protrudes through the hole on the bottom corner of the board.
    댓글 쓰기
  42. Joy-Con 2 (Left) Joystick Replacement: 42 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 42 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the 3.9 mm‑long silver screw securing the trigger button board.
    댓글 쓰기
  43. Joy-Con 2 (Left) Joystick Replacement, Install the bumper: 43 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the bumper: 43 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the bumper: 43 단계, 이미지 3개 중 3개
    • Align the two springs on the bumper with their two posts on the midframe, and press it into place.
    • The bumper is held in place by the front shell of the controller. If it falls out, ensure it's fully seated in the shell.
    댓글 쓰기
  44. Joy-Con 2 (Left) Joystick Replacement, Install the midframe screws: 44 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the midframe screws: 44 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the three 3.9 mm‑long silver screws securing the midframe.
    댓글 쓰기
  45. Joy-Con 2 (Left) Joystick Replacement, Install the bracket: 45 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the bracket: 45 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the bracket: 45 단계, 이미지 3개 중 3개
    • Align the release button bracket with its screw holes and set it in the frame so it snaps into place.
    • The corner with the protruding square should be facing the battery.
    댓글 쓰기
  46. Joy-Con 2 (Left) Joystick Replacement: 46 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 46 단계, 이미지 2개 중 2개
    • Use a JIS 00 driver to install the two screws securing the release button bracket:
    댓글 쓰기
  47. Joy-Con 2 (Left) Joystick Replacement, Install the trigger: 47 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger: 47 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the trigger: 47 단계, 이미지 3개 중 3개
    • Align the trigger button with the top of the controller, with the ZL engraving facing out.
    • Set the trigger button onto its metal spring. Ensure the legs of the metal spring are seated properly in their channels on the midframe.
    • Press firmly on the trigger button to snap it into place.
    • Check that the metal spring didn't fall out of position. If it did, remove the trigger, place it back into position, and try again.
    댓글 쓰기
  48. Joy-Con 2 (Left) Joystick Replacement, Install the release button: 48 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the release button: 48 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the release button: 48 단계, 이미지 3개 중 3개
    • Insert the release button into its bracket.
    • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
    댓글 쓰기
  49. Joy-Con 2 (Left) Joystick Replacement, Connect the battery: 49 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the battery: 49 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Connect the battery: 49 단계, 이미지 3개 중 3개
    • Align the battery connector over its socket on the board.
    • Press down on the connector until it's fully seated.
    댓글 쓰기
  50. Joy-Con 2 (Left) Joystick Replacement, Connect the rumble motor: 50 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Connect the rumble motor: 50 단계, 이미지 2개 중 2개
    • Align the rumble motor connector to its socket on the bottom edge of the board and push down until it's fully seated to connect it.
    댓글 쓰기
  51. Joy-Con 2 (Left) Joystick Replacement, Install the back cover: 51 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the back cover: 51 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the back cover: 51 단계, 이미지 3개 중 3개
    • Use an opening pick to press and hold the release button.
    • Place the back cover over the controller body so the release button cutout is slightly below the release button.
    • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
    • Press and slide the back cover up until the cutout for the release button is aligned with the button itself.
    • Ensure the rumble motor wires (blue & white) are fully within the frame.
    댓글 쓰기
  52. Joy-Con 2 (Left) Joystick Replacement: 52 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement: 52 단계, 이미지 2개 중 2개
    • Remove the opening pick.
    댓글 쓰기
  53. Joy-Con 2 (Left) Joystick Replacement, Install the left edge screws: 53 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the left edge screws: 53 단계, 이미지 2개 중 2개
    • Install the two screws on the left edge of the controller:
    댓글 쓰기
  54. Joy-Con 2 (Left) Joystick Replacement, Install the plastic strip: 54 단계, 이미지 3개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the plastic strip: 54 단계, 이미지 3개 중 2개 Joy-Con 2 (Left) Joystick Replacement, Install the plastic strip: 54 단계, 이미지 3개 중 3개
    • Align the clips on the plastic strip with their cut-outs on the controller body.
    • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
    댓글 쓰기
  55. Joy-Con 2 (Left) Joystick Replacement, Install the right edge screws: 55 단계, 이미지 2개 중 1개 Joy-Con 2 (Left) Joystick Replacement, Install the right edge screws: 55 단계, 이미지 2개 중 2개
    • Use a tri‑point Y00 driver to install the two 3.1 mm‑long black screws on the right edge of the controller.
    댓글 쓰기
결론
You finished fixing your Joy-Con 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nick Schultz
회원 가입일: 03/24/24
58,633 평판
안내서 318개를 작성함
3가이드 댓글
I used this to get at the left joycon's socket cable (Nintendo Switch 2 Left Joy-Con 2 Socket Cable) , it was excellent for taking apart the controller to that point even if I did not go the distance to the joystick.
The hardest part isn't the guide's fault since the controller does not make it easy to take apart, but be careful when removing the shoulder buttons to not lose track of the L button springs.
MrCab - 답글 공유
I did it! This guide is wonderful.
Edward Ocampo-Gooding - 답글 공유
Done! A little tricker then switch 1 joycons but doable for detail oriented non-techie.
brandon e - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 80
지난 7일: 684
지난 30일: 2,977
전체 시간: 20,668
