주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keyboard Keys Replacement Guide
필요한 것
  1. Keyboard Keys Replacement Guide, Keyboard Keys: 1 단계, 이미지 3개 중 1개 Keyboard Keys Replacement Guide, Keyboard Keys: 1 단계, 이미지 3개 중 2개 Keyboard Keys Replacement Guide, Keyboard Keys: 1 단계, 이미지 3개 중 3개
    • Before placing, check that the key is properly orientated. The letter side should be face up.
    • Place the missing key onto the keyboard in the desired orientation. Once aligned, press firmly until the key snaps into place. This will not require large amounts of force. If it does not snap in, realign the key and try again.
    댓글 쓰기
  2. Keyboard Keys Replacement Guide: 2 단계, 이미지 1개 중 1개
    • Large rectangular keys need to be attached to the small metal bar to be attached properly. There are two ways to do this.
    댓글 쓰기
  3. Keyboard Keys Replacement Guide: 3 단계, 이미지 2개 중 1개 Keyboard Keys Replacement Guide: 3 단계, 이미지 2개 중 2개
    • Before installing, the plastic receivers on the on the bottom of key need to be lined up properly with the metal pins.
    • Option one is to line up the receivers with the metal bar from step 2 and apply pressure to attach.
    댓글 쓰기
  4. Keyboard Keys Replacement Guide: 4 단계, 이미지 3개 중 1개 Keyboard Keys Replacement Guide: 4 단계, 이미지 3개 중 2개 Keyboard Keys Replacement Guide: 4 단계, 이미지 3개 중 3개
    • Option two is to be used if the key cannot be attached without removing the metal bar.
    • Pull the metal bar gently from one side to unseat it from the keyboard and allow it to be removed.
    • Attach the metal bar to the receivers on the back of the key.
    • Seat the metal bar into the hole on one side, and then the other. Then press firmly to attach the key.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Steven Park
회원 가입일: 03/09/16
420 평판
안내서 3개를 작성함
UMass Dartmouth, Team 7-5, Catania Spring 2016 UMass Dartmouth, Team 7-5, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
Great guide! One thing worth adding: laptop keys actually come in three retainer clip types — standard scissor (most common, two interlocking plastic arms), butterfly/inverted V (older MacBooks, very fragile), and snap-on single-piece clips (found on some Lenovo ThinkPads). The rubber cup underneath is equally important — if it's flattened or torn, the key will feel mushy even after reinstalling the cap. When diagnosing a wobbly key, check whether the clip is bent or cracked at the hinge point before ordering a replacement, since that's the component that fails most often.
Jeff Horton - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 39
지난 30일: 195
전체 시간: 14,780
