주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Paperwhite 12th Gen Battery Replacement
필요한 것
  1. Kindle Paperwhite 12th Gen Battery Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 Kindle Paperwhite 12th Gen Battery Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Use an opening tool or opening picks and insert the tip between the back case and screen.
    • Slide the opening tool around the edge of the tablet to release the clips holding them together and avoid damaging the connectors.
    • You can also place additional opening picks in the space between the top and bottom case to prevent the front and back cases from snapping back together.
    댓글 쓰기
  2. Kindle Paperwhite 12th Gen Battery Replacement: 2 단계, 이미지 2개 중 1개 Kindle Paperwhite 12th Gen Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the Kindle over and remove back casing from screen and device.
    • When reassembling, align the top and bottom case and press until they click into place.
    댓글 쓰기
  3. Kindle Paperwhite 12th Gen Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 Kindle Paperwhite 12th Gen Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • Work carefully: don't pry on or accidentally scrape any small, surface-mounted components on the board.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    댓글 쓰기
  4. Kindle Paperwhite 12th Gen Battery Replacement: 4 단계, 이미지 2개 중 1개 Kindle Paperwhite 12th Gen Battery Replacement: 4 단계, 이미지 2개 중 2개
    • The battery is attached to the case with an adhesive.
    • Use a black nylon spudger and slide it under the sides of the battery to create a gap between the battery and the housing.
    • Use a black nylon or plastic spudger when possible. Using a metal spudger can result in damage to the device.
    • Avoid prying along the top of the battery, as the base model lacks support on those sides. Take care not to bend or warp the battery during removal, as this could cause long-term damage.
    • Once the battery has loosened from the adhesive, use the black nylon spudger to gently lift and fully detach it while applying light upward pressure.
    댓글 쓰기
  5. Kindle Paperwhite 12th Gen Battery Replacement: 5 단계, 이미지 3개 중 1개 Kindle Paperwhite 12th Gen Battery Replacement: 5 단계, 이미지 3개 중 2개 Kindle Paperwhite 12th Gen Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Loosen the battery from the backing, then insert an opening pick on each side of the battery to help pry it off. Once the picks are in place, carefully peel the battery away and remove it from the device.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Ruby Powell
회원 가입일: 02/23/25
197 평판
안내서 1개를 작성함
1가이드 댓글
Where can I buy a replacement battery? What's the part number? I searched online but couldn't find it, thanks.
Massimo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 43
지난 30일: 241
전체 시간: 2,664
