주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Paperwhite 2nd Generation Charging Port Replacement
필요한 것
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
      • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
      댓글 쓰기
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Charging Port Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      댓글 쓰기
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully remove the mid-frame from the back cover.
      댓글 쓰기
    4. Kindle Paperwhite 2nd Generation Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Charging Port Replacement: 4 단계, 이미지 2개 중 2개
      • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
      댓글 쓰기
    5. Kindle Paperwhite 2nd Generation Charging Port Replacement: 5 단계, 이미지 1개 중 1개
      • Carefully lift the battery and remove it from the device.
      댓글 쓰기
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
      • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
      • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
      댓글 쓰기
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Charging Port Replacement: 7 단계, 이미지 2개 중 2개
      • Gently disconnect the zif connectors.
      • Some of these connectors are very thin and fragile, handle with care!
      댓글 쓰기
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: 8 단계, 이미지 3개 중 1개 Kindle Paperwhite 2nd Generation Charging Port Replacement: 8 단계, 이미지 3개 중 2개 Kindle Paperwhite 2nd Generation Charging Port Replacement: 8 단계, 이미지 3개 중 3개
      • Gently remove the motherboard.
      댓글 쓰기
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Charging Port: 9 단계, 이미지 1개 중 1개
      • The charging port is integrated in to the device motherboard.
      • From here, to fix a faulty port, either replace the entire motherboard, or carefully desolder the old port and solder a new one on in its place.
      • Check out the soldering guide for help.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tyler Davis
회원 가입일: 09/15/16
2,007 평판
안내서 5개를 작성함
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G2
4 회원들
안내서 31개를 작성함
10가이드 댓글
How to replace the USB port; replace the motherboard. Kind of a lame fix if you ask me. Whatever happened to soldering a new port on?
Sam Hardeman - 답글 공유
I have not done the fix yet but plan to replace the USB which appears to be a USB - micro B USB 2.0 Receptacle Connector 5 Position Surface Mount available at DigiKey. Is there any reason not to attempt this? I have microscope and soldering station. If not, where do you get the motherboard and how much is it?
Bill Smith - 답글 공유
Any updates? Did you run into any issues?
theend12212012 - 답글 공유
Démontage facile effectivement, mais les cinq microsoudures sur la carte mère sont impossibles à faire avec un simple fer à souder ! Il faut utiliser du matériel pour CMS (composant à montage en surface)…
Ceci dit mon problème vient effectivement de ces microsoudures. En appuyant simplement sur ces contacts mon Kindle s’est remis en marche ! Vive le travail mal fait à la construction…
telerando - 답글 공유
Getting the Kindle open and getting to the charging port was quite ‘easy’. In step 1 the top is stuck on with something like sticky back tape and the top can be gently pulled away from the tape.
Having got to the port I can not figure out how to replace it. This part does not seem to be easy, unless Step 9 is explained in much more detail. The contacts for the port seem to be incredibly small and I can’t figure out how they’re connected, or what part I need to order to replace the port.
Richard Garside - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 42
지난 30일: 251
전체 시간: 32,360
