주요 콘텐츠로 건너뛰기
Knog Blinder R70 battery Replacement
Andy Pleming
Andy Pleming다른 한 명의 기여자
최종 수정일 December 10, 2024
예상시간 없음
조정
커뮤니티-기여 안내서
If your R70 remains on red (rather than green) after charging over 8 hours, you may assume the battery is knackered. Refrence the photo, you need to get to the insides to replace it. (1) to remove the metal surrounding to the red plastic you will need to create (say with a knife) an indent to allow you to use a small screwdriver head to lever it off. You can see where I have done this in the photo. (2) The metal surronding to the remaining bottom side: this should be easy to lever off. You should detedt in the photo that this is thin surrounding has been detached and pushed to the back of the light.
Remove the red light cover to observe the circuit board (see the "Steps" photo).
Now the tricky part: finding a replacement battery. I will never buy Knogg again until, like Apple, they stop protecting their commercial interests over re-usability. The battery (in the main photo) is an unusual size: "851746": in mm: height 8.5, width 17, length 46. You could spend hours looking for this on Tinternet, I did, and it suggests to me that Knogg have deliberately made this obscure: be ashamed of yourselves, very ashamed.
Eventually, I found a couple of candidates, regrettably on eBay:
1) 702050 height 7.0, width 20, length 50 (the width is was too much risk vs. 17mm): https://www.ebay.co.uk/itm/172447064622
2) 801350 height 8.0, width 13, length 50 (the length is a squeeze, I will update if it squeezes in once deliverd from Shenzen in a month): https://www.ebay.co.uk/itm/254702307003?...
UPDATE: 801350 fits
3) I fitted 801350 OK, it was difficult to get the slim water proof rubber seal around the light so I added electrical tape around to ensure water proof.
  1. Knog Blinder R70 battery Replacement, battery: 1 단계, 이미지 1개 중 1개
    • This is the bottom of the circuit board that you will see, the battery wires are the black and red: you need to detach them from teh circuit board with a soldering gun, ready to solder in the new battery with its connectin wires.
결론
작성자
1다른 기여자 명과 함께
Andy Pleming
회원 가입일: 04/05/23
169 평판
안내서 2개를 작성함
댓글 한 개
UPDATE: 801350 fits
Andy Pleming - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 20
전체 시간: 354
