주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kodak EasyShare CD82 Lens Assembly Replacement
필요한 것
    1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3개 중 1개 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3개 중 2개 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3개 중 3개
      • Remove the batteries and the memory card from the device.
      • Remove the two screws located at the bottom of the camera.
      댓글 쓰기
    2. Kodak EasyShare CD82 Lens Assembly Replacement: 2 단계, 이미지 3개 중 1개 Kodak EasyShare CD82 Lens Assembly Replacement: 2 단계, 이미지 3개 중 2개 Kodak EasyShare CD82 Lens Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the two screws on the side of the device, to left of the camera lens.
      • Remove the two screws on side of the device, to the right of the camera lens.
      • Pry the casing apart at the seems, starting at the battery compartment.
      댓글 쓰기
    3. Kodak EasyShare CD82 Lens Assembly Replacement: 3 단계, 이미지 3개 중 1개 Kodak EasyShare CD82 Lens Assembly Replacement: 3 단계, 이미지 3개 중 2개 Kodak EasyShare CD82 Lens Assembly Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the front casing from the mid-frame, first.
      • Continue to remove the back casing from the mid-frame.
      • Do not remove the LCD screen from the device once it becomes visible.
      댓글 쓰기
    4. Kodak EasyShare CD82 Lens Assembly Replacement: 4 단계, 이미지 3개 중 1개 Kodak EasyShare CD82 Lens Assembly Replacement: 4 단계, 이미지 3개 중 2개 Kodak EasyShare CD82 Lens Assembly Replacement: 4 단계, 이미지 3개 중 3개
      • Flip the LCD screen out of the holder from the top to reveal ribbon cable.
      • This camera had some obvious water damage..
      • Remove the three screws from the LCD holder
      • Dislodge the LCD screen holder from the circuit board connector.
      댓글 쓰기
    5. Kodak EasyShare CD82 Lens Assembly Replacement: 5 단계, 이미지 3개 중 1개 Kodak EasyShare CD82 Lens Assembly Replacement: 5 단계, 이미지 3개 중 2개 Kodak EasyShare CD82 Lens Assembly Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Disconnect the logic board from the frame on the right side of the device.
      • Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
      • Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
      • Move the black clip into the upward position to disconnect the cable.
      • You will now be able to remove the LCD screen and its holder from the device.
      댓글 쓰기
    6. Kodak EasyShare CD82 Lens Assembly Replacement: 6 단계, 이미지 3개 중 1개 Kodak EasyShare CD82 Lens Assembly Replacement: 6 단계, 이미지 3개 중 2개 Kodak EasyShare CD82 Lens Assembly Replacement: 6 단계, 이미지 3개 중 3개
      • Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
      • Remove the two screws securing the lens to the midframe.
      • These are missing screws for the CCD sensor, lost in a previous dismantling.
      • Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
      • Push the lens out of the frame in an angular direction, and remove.
      댓글 쓰기
    7. Kodak EasyShare CD82 Lens Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Insert the new lens the same way it was removed.
      • Clean and reassemble the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
858,351 평판
안내서 123개를 작성함
1가이드 댓글
When it says "Dislodge the LCD screen holder from the circuit board connector" does it mean that I can break that solder without desoldering and it's okay?
Sith Siri - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 44
전체 시간: 2,305
