주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kurio 7 Speaker Replacement
필요한 것
    1. Kurio 7 Speaker Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Kurio 7 Speaker Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Kurio 7 Speaker Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
      • Begin by removing the rubber cover from the Kurio 7.
      댓글 쓰기
    2. Kurio 7 Speaker Replacement: 2 단계, 이미지 2개 중 1개 Kurio 7 Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 30 mm Phillips #00 screws from the outer case.
      댓글 쓰기
    3. Kurio 7 Speaker Replacement: 3 단계, 이미지 2개 중 1개 Kurio 7 Speaker Replacement: 3 단계, 이미지 2개 중 2개
      • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
      • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
      • Be careful not to break off the tabs that hold the front cover and the back cover together.
      댓글 쓰기
    4. Kurio 7 Speaker Replacement: 4 단계, 이미지 2개 중 1개 Kurio 7 Speaker Replacement: 4 단계, 이미지 2개 중 2개
      • Once all of the tabs are removed, the back cover should come off easily.
      • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
      댓글 쓰기
    1. Kurio 7 Speaker Replacement, Kurio 7 Motherboard Removal Guide: 5 단계, 이미지 2개 중 1개 Kurio 7 Speaker Replacement, Kurio 7 Motherboard Removal Guide: 5 단계, 이미지 2개 중 2개
      • Use a plastic credit card, or other thin object, to separate the battery from the screen.
      • Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
      • Carefully set the battery aside.
      댓글 쓰기
    2. Kurio 7 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Kurio 7 Speaker Replacement: 6 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
      댓글 쓰기
    3. Kurio 7 Speaker Replacement: 7 단계, 이미지 3개 중 1개 Kurio 7 Speaker Replacement: 7 단계, 이미지 3개 중 2개 Kurio 7 Speaker Replacement: 7 단계, 이미지 3개 중 3개
      • Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
      • Pull the ribbon out of the mount.
      댓글 쓰기
    4. Kurio 7 Speaker Replacement: 8 단계, 이미지 1개 중 1개
      • There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
      • Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
      • To remove the ribbon from the mount, follow the same steps in Step 3.
      댓글 쓰기
    5. Kurio 7 Speaker Replacement: 9 단계, 이미지 1개 중 1개
      • Pull back the ribbons and put the battery near the bottom of the Kurio.
      • The motherboard is now removed so that other components can be worked on.
      댓글 쓰기
    1. Kurio 7 Speaker Replacement, Speaker: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Pull the wires off of the motherboard using the tweezers. The wires aren't soldered on well.
      • Before you do break the solder, check the wires connections. You may be able to just solder the wire if it is already broken off.
      댓글 쓰기
    2. Kurio 7 Speaker Replacement: 11 단계, 이미지 2개 중 1개 Kurio 7 Speaker Replacement: 11 단계, 이미지 2개 중 2개
      • Remove any hot glue residue holding the speaker in place by peeling it off using tweezers.
      댓글 쓰기
    3. Kurio 7 Speaker Replacement: 12 단계, 이미지 3개 중 1개 Kurio 7 Speaker Replacement: 12 단계, 이미지 3개 중 2개 Kurio 7 Speaker Replacement: 12 단계, 이미지 3개 중 3개
      • Use the spudger to pry out the old speaker.
      • You have successfully removed the speaker!
      댓글 쓰기
결론
Solder in the new speaker. Refer to the soldering guide if you're unsure on how to solder. To reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Alex Powaser
회원 가입일: 04/14/14
331 평판
안내서 2개를 작성함
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014 회원
CPSU-MANESS-S14S12G36
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 36
전체 시간: 2,390
