주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG CF360 LCD Screen Replacement
필요한 것
  1. LG CF360 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG CF360 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
    댓글 쓰기
  2. LG CF360 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Lift and remove the battery.
    댓글 쓰기
  3. LG CF360 LCD Screen Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 LG CF360 LCD Screen Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two screw covers at the top of phone with tweezers.
    댓글 쓰기
  4. LG CF360 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the six Phillips #000 (3mm) screws.
    댓글 쓰기
  5. LG CF360 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 LG CF360 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 LG CF360 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
    댓글 쓰기
  6. LG CF360 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
    댓글 쓰기
  7. LG CF360 LCD Screen Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 LG CF360 LCD Screen Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
    댓글 쓰기
  8. LG CF360 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove the blue transparent tape from the connector.
    댓글 쓰기
  9. LG CF360 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
    댓글 쓰기
  10. LG CF360 LCD Screen Replacement, Front Case: 10 단계, 이미지 1개 중 1개
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
    댓글 쓰기
  11. LG CF360 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
    댓글 쓰기
  12. LG CF360 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the two red sticker screw coverings at the top corners with tweezers.
    댓글 쓰기
  13. LG CF360 LCD Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
    댓글 쓰기
  14. LG CF360 LCD Screen Replacement: 14 단계, 이미지 2개 중 1개 LG CF360 LCD Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
    댓글 쓰기
  15. LG CF360 LCD Screen Replacement, LCD Screen: 15 단계, 이미지 1개 중 1개
    • Be very careful to not damage the green keypad board when using the plastic opening tool.
    • Use a plastic opening tool to carefully disconnect the silver L-shaped LCD screen ribbon.
    댓글 쓰기
  16. LG CF360 LCD Screen Replacement: 16 단계, 이미지 2개 중 1개 LG CF360 LCD Screen Replacement: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • At this point, an orange ribbon is still connected to the white and black Zero Insertion Force (ZIF) connector on the keypad board. Be careful to not damage the ribbon.
    • Use tweezers to carefully pry up the black retainer on the connector.
    댓글 쓰기
  17. LG CF360 LCD Screen Replacement: 17 단계, 이미지 2개 중 1개 LG CF360 LCD Screen Replacement: 17 단계, 이미지 2개 중 2개
    • Lift the keypad board away from the phone casing using a plastic opening tool.
    • Slowly rotate the keypad board towards you to disconnect the second orange LCD screen ribbon and remove the board.
    댓글 쓰기
  18. LG CF360 LCD Screen Replacement: 18 단계, 이미지 1개 중 1개
    • If you have never soldered before, or need a refresher, take a look at iFixit's soldering guide before starting this step.
    • Use a soldering iron and a solder wick to de-solder the 4 wires connected to the LCD screen.
    • The LCD screen can easily be removed at this point by lifting it from the phone casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ricky Wai
회원 가입일: 10/15/13
299 평판
안내서 2개를 작성함
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G27
4 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 36
전체 시간: 1,647
