주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Main Board Replacement
필요한 것
  1. LG Front Load Washing Machine Main Board Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    댓글 쓰기
  2. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    댓글 쓰기
  3. LG Front Load Washing Machine Main Board Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel towards the rear of the device to disconnect its clips.
    댓글 쓰기
  4. LG Front Load Washing Machine Main Board Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    댓글 쓰기
  5. LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: 5 단계, 이미지 2개 중 2개
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
    댓글 쓰기
  6. LG Front Load Washing Machine Main Board Replacement: 6 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the hose from the pressure sensor.
    댓글 쓰기
  7. LG Front Load Washing Machine Main Board Replacement, Unfasten the pressure sensor: 7 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the pressure sensor.
    댓글 쓰기
  8. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: 8 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: 8 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: 8 단계, 이미지 3개 중 3개
    • Unclip the pressure sensor from the chassis or other components.
    댓글 쓰기
  9. LG Front Load Washing Machine Main Board Replacement: 9 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the pressure sensor away chassis and remove it.
    댓글 쓰기
  10. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: 10 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: 10 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: 10 단계, 이미지 3개 중 3개
    • Disconnect any cables or fasteners secured to the control panel cover.
    • Repeat this procedure for any bundled cables that keep the cover from opening.
    댓글 쓰기
  11. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: 11 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: 11 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: 11 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver or a prying tool, to unclip the main board cover.
    • Remove the main board cover.
    댓글 쓰기
  12. LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: 12 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: 12 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the main board to the back side of the washer.
    댓글 쓰기
  13. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: 13 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: 13 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: 13 단계, 이미지 3개 중 3개
    • Slide the main board out of its slot in the chassis.
    댓글 쓰기
  14. LG Front Load Washing Machine Main Board Replacement, Remove the main board: 14 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Main Board Replacement, Remove the main board: 14 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Main Board Replacement, Remove the main board: 14 단계, 이미지 3개 중 3개
    • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
    • Lift the main board out of the chassis to access each of the connectors.
    • Disconnect each connector from the main board.
    • Remove the main board.
    댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
39,920 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,572개를 작성함
1가이드 댓글
Thank you for the instructions. Can power to the front control panel be tested without connecting the pressure sensor and water lines.
albert - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 28
지난 30일: 101
전체 시간: 4,155
