주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Stator Replacement
필요한 것
    1. LG Front Load Washing Machine Stator Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Stator Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      댓글 쓰기
    1. LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
      • Remove the screw(s) securing the rear panel.
      댓글 쓰기
    2. LG Front Load Washing Machine Stator Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
      • Unclip the rear panel from the chassis.
      댓글 쓰기
    3. LG Front Load Washing Machine Stator Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the rear panel.
      댓글 쓰기
    1. LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: 5 단계, 이미지 2개 중 2개
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      댓글 쓰기
    2. LG Front Load Washing Machine Stator Replacement, Remove the rotor: 6 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Stator Replacement, Remove the rotor: 6 단계, 이미지 2개 중 2개
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      댓글 쓰기
    1. LG Front Load Washing Machine Stator Replacement, Unfasten the motor harness: 7 단계, 이미지 1개 중 1개
      • Remove the screw(s) securing the motor harness.
      댓글 쓰기
    2. LG Front Load Washing Machine Stator Replacement, Unfasten the stator: 8 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Stator Replacement, Unfasten the stator: 8 단계, 이미지 2개 중 2개
      • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
      • Remove the bolts securing the stator.
      • During reassembly, refasten the screws in a "star" pattern.
      댓글 쓰기
    3. LG Front Load Washing Machine Stator Replacement, Reposition the stator: 9 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Stator Replacement, Reposition the stator: 9 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Stator Replacement, Reposition the stator: 9 단계, 이미지 3개 중 3개
      • Don't pull the stator too far away from the device, as it's still connected by wires.
      • Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
      댓글 쓰기
    4. LG Front Load Washing Machine Stator Replacement, Disconnect the stator: 10 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: 10 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: 10 단계, 이미지 3개 중 3개
      • Disconnect the connectors attached to the stator.
      • Always grip cables by their connectors and not the wires themselves.
      댓글 쓰기
    5. LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: 11 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: 11 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: 11 단계, 이미지 3개 중 3개
      • Use your fingers to unclip the rotor position sensor from the stator.
      • Pull the sensor away from the stator to completely unclip it.
      • Remove the rotor position sensor.
      • You're left with the stator.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,177 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 61,652개를 작성함
5가이드 댓글
I don’t have comment just question. Does this particular model have a drive belt? Mine is not spinning properly
Leilani Seymour - 답글 공유
No it does not. It is a direct drive machine, meaning that the motor drives the wash basket directly. Take a look at this link for some help.
Bill Gilbert - 답글 공유
I undertook this repair with the wd14071sd6 model to replace the hall sensor as I was getting the LE error code. I have noted on step 2 that the entire back panel had to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
Despite this, the repair can be achieved without any major electric disconnection work just a matter or having enough space to carefully remove things.
Phill Birtles - 답글 공유
Te alguns estator que não usam o sensor Hall a minha lava seca LG wd17vts6 está máquina tem sensor Hall no estator
Dúvidas, obrigado
ROMUALDO GUIMARAES - 답글 공유
A máquina LG wd17vrs6 (modelo) usa sensor Hall no seu estator
Dúvida poderia me informar
Obrigado
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 88
전체 시간: 2,504
