주요 콘텐츠로 건너뛰기
LG K20 PLUS Ear Speaker Replacement
Patrick
Patrick다른 한 명의 기여자
최종 수정일 December 5, 2021
예상시간 없음
조정
커뮤니티-기여 안내서
필요한 것
도구
더보기...
  1. LG K20 PLUS Ear Speaker Replacement, Remove the back cover and battery: 1 단계, 이미지 2개 중 1개 LG K20 PLUS Ear Speaker Replacement, Remove the back cover and battery: 1 단계, 이미지 2개 중 2개
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Ear Speaker Replacement, Midframe: 2 단계, 이미지 1개 중 1개
    • Remove 11 Philips screws.
  3. LG K20 PLUS Ear Speaker Replacement: 3 단계, 이미지 2개 중 1개 LG K20 PLUS Ear Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Ear Speaker Replacement, Rear-Facing Camera: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Ear Speaker Replacement, Motherboard Removal: 5 단계, 이미지 1개 중 1개
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
  6. LG K20 PLUS Ear Speaker Replacement, Ear Speaker Removal: 6 단계, 이미지 1개 중 1개
    • The flex cable and speaker are held in with adhesive. Use heat to soften the adhesive.
    • Carefully insert a Jimmy between the flex cable and the frame and detach the cable from the adhesive.
    • Then use the tip of a metal spudger to continue carefully prying the ear speaker up out of its housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Patrick
회원 가입일: 05/14/14
6,613 평판
안내서 21개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 1,076
