주요 콘텐츠로 건너뛰기
LG K40S Fingerprint Scanner Replacement
JoshAtticus
JoshAtticus다른 한 명의 기여자
최종 수정일 August 20, 2024
5 - 10 분
쉬움
커뮤니티-기여 안내서
Use this guide to replace the fingerprint scanner in your LG K40S
필요한 것
부품
도구
더보기...
  1. LG K40S Fingerprint Scanner Replacement, Precautions: 1 단계, 이미지 3개 중 1개 LG K40S Fingerprint Scanner Replacement, Precautions: 1 단계, 이미지 3개 중 2개 LG K40S Fingerprint Scanner Replacement, Precautions: 1 단계, 이미지 3개 중 3개
    • Power off your phone by holding the power key, pressing power off, then confirm.
    • Make sure that the battery of your phone is below 25% before opening to avoid battery fires should an accident happen.
  2. LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: 2 단계, 이미지 3개 중 1개 LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: 2 단계, 이미지 3개 중 2개 LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: 2 단계, 이미지 3개 중 3개
    • Use a SIM Eject tool (real one, bent paperclip or otherwise) to eject the 2 SIM & SD Card trays before removing them from the phone.
  3. LG K40S Fingerprint Scanner Replacement, Removing back panel: 3 단계, 이미지 3개 중 1개 LG K40S Fingerprint Scanner Replacement, Removing back panel: 3 단계, 이미지 3개 중 2개 LG K40S Fingerprint Scanner Replacement, Removing back panel: 3 단계, 이미지 3개 중 3개
    • The back panel is made of plastic significantly reducing the chance of breakage compared to a glass back.
    • The back panel is held on with plastic clips and can be unclipped using plastic picks.
    • Be careful around the buttons so as to not damage the flex cables they reside on. The buttons on the back panel are seperate from the flex cable containing the buttons
    • Do not fully pull the back panel off straight away, you may rip the flex cable for the fingerprint scanner.
  4. LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: 4 단계, 이미지 3개 중 1개 LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: 4 단계, 이미지 3개 중 2개 LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: 4 단계, 이미지 3개 중 3개
    • Open the back panel to the right as shown in image 1.
    • Disconnect the fingerprint scanner flex cable using a plastic pick or spudger
    • Pull the back panel away from the phone.
  5. LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: 5 단계, 이미지 3개 중 1개 LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: 5 단계, 이미지 3개 중 2개 LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: 5 단계, 이미지 3개 중 3개
    • Carefully remove the black tape covering the fingerprint scanner using your fingers or a plastic pick, being careful not to insert your pick too far if using one.
    • Carefully push the fingerprint scanner through the back panel.
    • Use a plastic pick to carefully unadhere the flex cable from the back panel.
    • Pull the fingerprint sensor away from the back panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
JoshAtticus
회원 가입일: 04/08/23
275 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 8
전체 시간: 87
