LG K7 Battery Replacement
Replacing a battery is a simple process, but be careful when handling the battery. A damaged battery is highly toxic, so keep safe if you notice any physical damage to your battery.
Place a fingernail in slot at in the bottom edge of the phone.
Pull up on the back panel while holding down the rest of the phone steady with your hand.
다른 한 분이 해당 안내서를 완성하였습니다.
