주요 콘텐츠로 건너뛰기
LG K7 Charging Port Replacement
Stephen Damm
Stephen Damm2 다른 기여자
최종 수정일 December 8, 2021
30 분
어려움
The charging port allows for the LG K7 to be charged. It can stop working for a number of reasons but the main two are shock and wear. It can be replaced in about 30 minutes with the guide below. A soldering iron will be necessary which should be used with caution.
필요한 것
도구
더보기...
  1. LG K7 Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 LG K7 Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Remove the back cover by using the plastic opening tool.
    • Remove battery by using the plastic opening tool.
  2. LG K7 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  4. LG K7 Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
  5. LG K7 Charging Port Replacement: 5 단계, 이미지 2개 중 1개 LG K7 Charging Port Replacement: 5 단계, 이미지 2개 중 2개
    • Heat up the four connection points using a soldering iron.
    • Once hot, gently push the port off.
    • Soldering iron is hot! Use with caution.
    • Be careful not to touch other components with the soldering iron.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Stephen Damm
회원 가입일: 11/07/19
167 평판
안내서 1개를 작성함
IUPUI, Team S3-G2, Harley Fall 2019 IUPUI, Team S3-G2, Harley Fall 2019 회원
IUPUI-HARLEY-F19S3G2
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 7
전체 시간: 592
