주요 콘텐츠로 건너뛰기
LG K7 Headphone Jack Replacement
James Ngo
James Ngo다른 한 명의 기여자
최종 수정일 December 8, 2021
10 분
조정
A malfunctioning headphone jack is often the problem if you are experiencing a lack of audio through headphones. Replacement headphone jacks can be found online.
필요한 것
도구
  1. LG K7 Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG K7 Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Headphone Jack Replacement: 2 단계, 이미지 2개 중 1개 LG K7 Headphone Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 3개 중 1개 LG K7 Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 3개 중 2개 LG K7 Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 3개 중 3개
    • Remove the nine frame screws with a #J00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Headphone Jack Replacement: 4 단계, 이미지 2개 중 1개 LG K7 Headphone Jack Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to separate the screen from the outer frame.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Headphone Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Line up a plastic opening tool underneath the headphone jack and hold the main body of the phone down.
    • Lift or the plastic opening tool to separate the headphone jack from the main body of the phone.
    • Be careful to not damage the components that the headphone jack sits in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
James Ngo
회원 가입일: 01/19/18
461 평판
안내서 4개를 작성함
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S21G5
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 975
